Question about GE Energy Star WCVH6260F Front Load Washer
GE front load king size washer gasket is ripped and warrantee is expired
This site is absolutely useless
Posted on Sep 11, 2009
  • 83 Answers
Http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Posted on Sep 09, 2009
For a king size bedwill colossal size wash a quilt
yes I would say these machines will wash this item
should be gentle cycle and max water level settings.
I can confirm kenmores xtra capacity machine does.
If material is delicate or fragile any, the large frontload
machines at local laundromats will be appropriate for this job.
hope this info will be helpful, PAUL Douglas Calif.
Sep 14, 2014 | GE WBSR3140DW Top Load Washer
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
The rubber lining has ripped in my king size front loader after 16 months would this be under warranty
Do you mean the bellows around the door area has ripped and yes this would be covered if your warranty was still in effect if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks RIck
Jun 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load GE wcvh6260hww gasket is ripped Where do i get a new one and how do i replace?
I have not replaced a gasket myself (had warranty service) but when it was complete, I made sure to tilt the washer slightly backwards so the clothes did not get into the gasket so easily. After two replacements in the first three months, we have not had to replace for more than two years. Hope this helps when you get the new one in.
Oct 16, 2010 | GE WSXH208A Front Load Washer
My ge front load washer has a substantial leak when it is running. it is leaking from the bottom of the unit. It is not the drain hose or a clog in the drain. But it leaks like crazy PLEASE HELP
Check the door gasket for rips. Also there is a gasket between the two halves of the the outer drum, check that for leaks. Look at the pump housing and the hose that connects the pump to the drum for leaks.
Aug 27, 2010 | GE WSXH208A Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
GE Front Load Rips Clothes
clothing tearing is usally from foreign objects in or on clothing such as zippers fastners belts etc try making sure all those things are fastened should help
May 29, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
98 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
