Question about NetGear WGT624 Wireless Router
Wireless network password - NetGear WGT624 Wireless Router
  • 1,272 Answers
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Hope, this helps.
Posted on Sep 09, 2009
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
How to secure my home network wifi how to put a password?! it appears that it's Unlocked..
Wireless network passwording is done at the router, in the wireless setup area. Log into your router using the admin userid and password. Go to wireless settings and there you will see the option to set a password for the wireless network. One you set the password and save it, all devices that connect to your network wirelessly will need to be reconnected to the network, using the password you selected to gain access to the network.
Sep 17, 2016 | SENAO High Power 200mW USB WiFi 802.11bg...
A NEED A PASSWORD
Are you looking for wireless network password or the router password.
The default linksys router password is admn.
If you are looking for the wireless network password then you will need to access the setup page of the router.
See How to find wireless network key.
See Video: How to find wireless network key.
Mar 31, 2012 | Linksys WRT54GX2 Wireless-G Broadband...
I forgot my password
Which password you are looking for?
If you are looking for wireless network password then you will need to access the router setup page and check the wireless settings.
IF you are looking for password to access router settings then default password of Linksys router is admin.
To check the wireless network password see How to find wireless network key WEP WPA
Jan 08, 2012 | Linksys Wireless-G Broadband Router
Are you looking for the router password or password to connect to the wireless network?
If you are looking for the wireless network password then you will need to check the wireless settings of your router.
Connect the computer to the router and open the setup page of the router.
Go to wireless tab and check the wireless network password.
Jan 05, 2012 | Computers & Internet
Reset password
Yes. If you change the password of the wireless network then other 2 units will get disconnected from wireless network (if they are connected to the wireless network. If these 2 units are wired to the router then it does not make any change)
I will suggest you to change the wireless network name also if you are changing the wireless network password.
Try to connect to the new wireless network on all the computers and devices.
Linksys router how to
Jan 02, 2012 | Linksys Wireless-G WRT54G Router
Don't know my password
Are you looking for wireless network password or Linksys router password?
If you are trying to connect to the wireless network then it might be asking you for the wireless network key or the passphrase.
You can open the setup page of the router and check the wireless settings.
Read Wireless network key WEP WPA
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
Having trouble with wireless networking adapter
An Xbox 360 console can connect to Xbox LIVE using your wireless network. You do, however, need to know your wireless network password.
You can find your wireless network password in the following places:
Find your password on your hardwareFind your password using Windows 7Find your password on the router configuration webpage
Oct 11, 2011 | Microsoft Wireless Network Adapter Xbox...
Where is the wifi password for my 2wire wireless router. trying to connect my iphone 3g for faster internet
the default wireless passowrd or network key is located at the bottom left of the 2wire router. You will find a sticker that indicates the Serial Number, System Password and Wireless Network Key. The Wireless Network Password is is the 10 Digit Code located under the S/N.
If in any case you want to personalize the Wireless Network Key. You can access the gateway by opening a browser the type 192.168.1.254 it will ask you for a password use the System Password on the sticker. Click on Home Network then Click on Wireless Settings. You can also change the Network Name or SSID, The Authentication and the Wireless Network Key
Thanks for using Fixya
Jul 29, 2010 | 2wire 2700HG-B Router (2700HGB)
How do I change my password?
are you speaking about the wireless network key . The password for the wireless network will depend upon the router. to change the wireless network pasword , you will need to change the settings of the router.
Open the set up page of the router and change the wireless network password.
Click here for more information
Mar 17, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
Nov 12, 2009 | Computers & Internet
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
