Question about Hitachi 42V710 42" Rear Projection HDTV
Picture has lots of green
I can see the other colors but the whole picture has a very noticeable green tint. tint and color adjustments do not help any. any ideas?
    Problem Solver:
  • 11 Answers
I think that your TV picture tube has a problem..tnx
Posted on Sep 09, 2009
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Apr 15, 2013 | Televison & Video
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Hitachi 42V710 42" Rear Projection HDTV Logo
455 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
