Question about Nikon Coolpix S210 Digital Camera
Dropped the Camera, Lens is stuck open
I dropped my camera on the floor, lens side hit the floor. Now the camera lens is stuck open. I turn the camera on and off and it wants to open/close but the lens stays out. It dented the lens a little bit. I want to know how to fix it, if I can even fix it and how much will it cost? Thank you!!
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Posted on Sep 23, 2009
I had the exact same problem when I dropped my camera about 5 feet onto concrete. I noticed the lens was jimmied to one side a little bit. It was stuck open and could not use the camera. I just pinched the lens and pulled it out and it works great now.
Posted on Nov 20, 2009
Camera lens cover won't open when you turn the camera on. Says "power off then on" but still stuck
This kind of problem occurs if camera dropped on floor that broke lens mechanism OR lens mechanism got dust particles that make it stuck.
Usually lens mechanism needs to be replaced to solve the issue, however, user level try to solve the problem is to tap camera on your palm a few time gently that may release stuck lens mechanism and it start working again, if that does not help then lens assembly will be replaced.
Thanks.
Jun 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Lens Stuck
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Mar 17, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Lens error: canon sx110is
I had the same thing happen to me and didn't use my camera for about two months. One day I decided to gently hit the side of the lens and the side of the camera closest to the lens as well. I still can't believe it, but my lens suddenly popped open and has been working fine ever since. Before this nothing had worked, including the gentle hitting of the side of the lens I had done before. I think I hit, or I should say thumped, the side of the lens a bit more forcefully this time. If your desperate, you might want to give it a try but make sure you keep thumping hit for a while before you give up. I think it dislodged some small particle that had been blocking the lens from opening up.
Apr 08, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Lens Stuck
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
Sep 08, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Dropped my camera on a hard surface and the lens is stuck open.
Buy a new one, that's what I did after I dropped my brand new camera.
Dec 16, 2006 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
779 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
