Printer says broken pipe. What's this? - Office Equipment & Supplies
How to disassemble espresso machine.My gasket leaks
i think its not a gasket problem may be broken pipe or broken thermal block if you have a broken pipe it is due to not cleaning the filters you get an over pressure on the internal pipes and bingo water come out be wear of electric
Sep 13, 2015 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
I got a 2005 homestead rv and the water pipe broke or froze up how can I check and fix it
Water pipes in RV are Pex, which is not the same as PVC. Pex will freeze, but is designed to not burst when frozen. If you have located the broken pipe, it is simple to replace. Using a PVC cutter (looks like cheap shears) cut out the broken piece. Most likely the pipe size will be 1/2 inch. Pex comes in three different colors: white, red, and blue. Most likely the RV pipe will be white, but the color does not matter as the pipe is of the same material. Pex can be bought at stores like Home Depot, Lowes, or other hardware stores. The connector fittings can be bought at the same stores. The simplest to use fittings are the push-on self sealing fittings. There are cheaper fittings, but they take special tools to install them. The estimated cost of a 2 foot distance pipe repair is about $10 to $15. The time required depends on how difficult it is to "get to" the broken pipe.
May 28, 2015 | Water Water Heaters
How do I fix a broken water pipe?
Plastic or metal? You have to get under the trailer to do this. You have to cut off the bad pipe and use new pipe. You should see about using shark bite connectors to make this easier.
Mar 24, 2015 | Water Water Heaters
Rear clunking noise when hit bumps
Could be
Exhaust pipe holder broken and pipe flopping when you hit a bump
Muffler too close to frame
Gas tank strap broken
Broken or shot shock absorber
Broken spring
With out being able see and hear it these are only suggestions.
Mar 02, 2015 | 2009 Pontiac G6
My print job stopped in the middle with the following message displayed on my Mac screen: "Unable to write print data; broken pipe". What's going on and how do I fix it? My system is wireless.
there is a inc suck up pipe the inc gets sucked up the pipe when the pipe is blocked it cannot remove spent ink or toner it will need cleaning out.
May 29, 2014 | HP Officejet Pro 8600
Message Hp 6500 Printer all in one says, broken pipe won't print from the computer ... every thing else works ok
Try shutting the computer off, unplug printer, and start it all up again.
How is the printer connected? check the cable and confirm it's plugged in fully.
May 06, 2014 | Office Equipment & Supplies
Broken copper tubing extension
on this pipe I plugged the extension by simply soldering a cap which you can buy at Lows home improvement for about 44 cents. 4_14_2014_7_06_29_am.jpg
Feb 27, 2014 | Plumbing
Samsung CLX 3185FW WiFi Printing from MacBook Pro.WPS connected, Unable to send trailing nul to printer.broken pipe. What does this mean???
it means that your printer is connected via WiFi but the data can not be transferd. Could be the distance to the printer is to far.
May 15, 2011 | Samsung Office Equipment & Supplies
How do I repair a broken tailpipe on my 2002 Sportage
Hi:
Depending on which section of exhaust pipe is broken, usually it is easiest to purchase a new pipe and new clamps , and install instead of repairing the old pipe. Chances are that what ever shape the section of pipe was that broke, the rest is soon to follow. You can stop by your local auto parts store, and see what pipes they offer for your car, as well as the muffler and needed clamps.
Mar 26, 2010 | 2002 Kia Sportage
Broken fitting
It is difficult but not impossible to remove the broken part with a lot of WD-40 and a good big pipe wrench. Then take the broken fitting to the hardware store and get one like it. Also purchase a tube of pipe dope and reassemble.
please mark this as a fixya!
Dec 07, 2008 | Plumbing
2,172 people viewed this question
jasbo
jasbo
