Question about Toshiba Satellite P205D-S7438 Notebook
Built in speakers don't work. I only hear popping sounds. What do I need to do?
  • aka152k5 Sep 09, 2009
    Thank you! I did that and I hear sound now. It still sounds low though.
    Problem Solver:
  • 11 Answers
The soundcard driver is not installed in your laptop..try to download or install the sound driver,,tnx
Posted on Sep 09, 2009
Testimonial: "I have sound. Still having a little problem, but at least I know I can get something."
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound coming from built in speaker
Is your computer custom built? Or a factory built one? If it's factory built I'm going to need the model name.. For an example I have a Dell A950. It's name can normally be found on the front or back.
I need this because I can't help you solve your problem if I have no idea what hardware you have. Therefore I can't know where to get the driver to fix your speaker. The built in speaker probably needs a specific driver to be used.
Apr 09, 2013 | Computers & Internet
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
I hear echo sound every time i play music/movie and i cant figure out to turn it off "how"
Does it happen with headphones in as well? If not, do you have a built-in-microphone? Sometimes the sound coming of the speakers can be picked up by the microphone, resulting in an echo sound. Make sure that the microphone is off (or test it by covering it up while playing some music), and quit out of any applications that are using it.
If you hear it in the headphones as well, it could be a sound card problem, which means it would need replacing. If you don't hear it in the headphones, but hear it in the speakers and don't have a mic, it's either your speakers, or (more likely) your computer just doesn't get along with whatever software you're using to play movies/music.
Sep 17, 2011 | Acer Aspire 6930-6771 Laptop
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Built in Speaker no output Sound.
If you can get inside the laptop, try reseating the speaker wires to the motherboard and if that doesn't work, then your speakers are blown are the moterhboard is bad.
Feb 09, 2009 | ASUS m6n Notebook
Headset and inbuilt speaker works at same time
Can you not just disable the built-in speakers in control panel while you're chatting on the mic?
-Aaron
Jul 30, 2008 | Acer Aspire 3680 Laptop
Toshiba Satellite P205D-S7438 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
