Question about Craftsman Garden
I have a cub cadet 1315 and it only starts when you wiggle the ignition wires but only sometimes
  • 108 Answers
The wire ends are either loss or conection are rusty if ends are loose get some new ends at the hardware or if prongs are dirty take the switch out and clean the ends on the prongs,thank you.
Posted on Dec 23, 2009
Cub cadet lt1046 pto will not engage . When I pull the switch it does nothing suggestions??
check under mower were it plugs into the clutch and be sure it is connected good. check fuse. test switch. test clutch. some times if you wiggle the wires going into the clutch it will engage if it does you may be able to take the clutch off and solder the wires where they are frayed.
Jun 08, 2017 | Cub Cadet Garden
How to change the fuse on a cub cadet riding mower
Most of the times the fuses on cub cadets are located under the engine cowling close to where the steering shaft runs through the frame near the battery. Follow the wiring harness from behind the ignition switch and it should lead you to the fuses. There are no very many fuses to check on your mower. Good luck and I hope this helps.
Sep 07, 2014 | Cub Cadet Garden
Where is the fuse located on a LT1554 cub cadet
Check the connector and wires at the pto clutch. Sometime the movement will create a cut in the wiring you may be able to see. If so if the wire touches ground it will blow the fuse and if the wires touch each other it will short. if the short is not there then the clutch is bad?
BMW PARTS
May 25, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Starting problems with my cub cadet 2166 lawn mower? Battery is good, not turning over, sometimes it clicks? I can jump start but it is a pain. I have taken this to a dealer last year for this problem....
If it works when jump started, then I would suspect a bad battery or lose or corroded connection. check wires from battery to starter relay also known as solenoid to starter,if it is making a click,the ignition is most likely ok . safety start switch is ok ,I still suspect Battery..can you have it load tested or try a known good one?PS if above test OK, then starter or starter solenoid /relay.Hope this helped you fix it. please let us know if this helped.thank you.
Mar 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
