Question about Whirlpool Dryers
How to install belt on whirlpool dryer lew 0050pq
    President:
  • 744 Answers
Hello, Here is a guide to replacing whirlpool dryer belt's with pictures: http://www.wonderhowto.com/how-to/article/replace-a-dryer-belt-on-whirlpool-models-0104520/ If you have any questions or concerns please feel free to comment again giving me time to respond. Good Luck!! Mike
Posted on Sep 09, 2009
What belt comes with whirlpool kit # 4392067?
If you have a whirlpool dryer with the lint filter that comes out of the top cover you would need belt #341241, Whirlpool Dryer Drive Belt 341241
That kit looks like a front-lint package...probably contains a #66157 belt. Whirlpool Dryer Drive Belt 661570V
Jul 06, 2016 | Whirlpool Dryers
Was drying cloth and just stop working, the element comes on but no running of drum
Most electric dryers are 220V and are essentially 2 -110V circuits.. You should have either 2 circuit breakers or two fuses supplying the power to the dryer . One is probably tripped or blown. Either reset the breaker or replace the defective fuse and you should be in bussiness!
Feb 16, 2011 | Whirlpool LER4634J Electric Dryer
Please, can you tell me how to tighten the belt on an Inglis dryer model J073500
Sorry for the troubles but you cant tighten the belts on those or any dryer for that matter. Here is the problem your belt is worn out and that's why it is loose and if you have replaced it and its loose you are installing the belt incorrectly around the idler pulley or have the wrong belt or your idler pulley is worn out. I hope this helps solve the issue your having and for instructions on installing the belt go to youtube and type in whirlpool dryer drum belt installation they will show you the correct way to do it and whirlpool builds your model dryer.
Jan 22, 2011 | Dryers
How to install a multi rib dryer belt on my
remove the back!! top lid take 2 bolts out of the inside top of the front panel and two screws on the lower outside front panel remove the belt if its still on the drum ! slide drum outwards about 6 inches then from the back of unit slide the belt around the motor shaft and then the drum and hook around the idler tensioner slide drum back and reassemble
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
My dryer is making a loud clunking sound with each rotation. When I look in the drum on the back center of it I see about 6 rivet that seem to be connecting the drum to something in the back. The holes...
It could be that your rollers are wore out and let the drum fall down. If you stick your hands inside of the drum can you lift it up with your hands like maybe the drum is down lower then it should be? And do this while not running of course. lol See if there is any slop in the drum with your hand lifting up and down on the drum. See if you can also pull it forward any.
Jul 29, 2009 | Whirlpool LEW0050P Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Install a dryer belt
depends on the brand. always post brand and model #.
if it is a whirlpool or kenmore the idler pulley will be laying in the bottom of dryer. the belt should have come with instructions as to how to loop it around motor pulley and Idler.
J
Jun 10, 2008 | Dryers
2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
May 12, 2008 | Dryers
Dryers Logo
244 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
