Question about Basic Remote Vehicle Alarm System
My bulldog Model 2010 Alarm is too sensitive and
My bulldog Model 2010 Alarm is too sensitive and goes off all the time how can I adjust the sensitive
  • 733 Answers
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Posted on Sep 09, 2009
Testimonial: "Wow thanks, I searched for an hour and never found anything this is great thanks again "
The alarm on my 2007 ford escape randomly goes off. how is this easily and cheaply fixed?
It depends what is setting it off. If it is just a loose door latch, it is usually easy to fix. Lock the car and set the alarm. Pull on each door handle to see if a door switch opens and sets off the alarm. If it does, adjust the latch on the door to close the door more fully.
If it is not a door switch, maybe the inertia switch is too sensitive. Unless your model has an adjustable sensitivity, that problem is harder to solve.
Aug 12, 2017 | Ford Cars & Trucks
My Holden Barina 2010 hatchback alarm goes off (usually when windy conditions). How can this be fixed?
talk with a service dealer and see if the sensitivity of the alarm can be adjusted
Jun 06, 2016 | Holden Cars & Trucks
Alarm goes off when unlocked and undisturbed why?
Jeff, maybe sensitivity can be adjusted, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Adjust Car Alarm eHow
2008 Toyota Tacoma Alarm too sensitive
Thread How to adjust the sensitivity of car alarm
http://www.driveaccord.net/forums/51-8th-generation/60017-oem-alarm-sensitivity-setting.html
Mar 23, 2016 | Cars & Trucks
Car alarm very sensitive
Factory system or added on to the factory system that all LR's come with.
Jun 09, 2014 | 2010 Land Rover Range Rover Sport
2002 mountaineer arlarm goes off randomly
My bet is that the alarm goes off when it is windy or when a large truck passes by. If that appears to be the case, the tamper alarm sensitivity needs to be adjusted so that it is less sensitive to movement of the truck.
Jan 23, 2013 | 2002 Mercury Mountaineer
Someone programmed their remote into my Bulldog 2010 alarm brain and is deactivating my alarm and then vandalizing my car. How do I get rid of their programming instructions and neutralize their remote?
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Dec 17, 2009 | Basic Remote Vehicle Alarm System
I have installed a bulldog security rs82p on a 2004 merc sable. The bypass module used was originally labeled as a model 20402,23402,27402,&29402. This is now the 791 the unit turns on but does NOT...
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
Oct 25, 2009 | Bulldog& Remote Alarm System With 1-wire...
My alarm is to sensitive What can i do to bring it down alot so a loud car dont set it off
there is usually a setting on the shock sensor it self via a dial, or sometimes there is a combination on the key pad that will adjust the sensitivity. Try to find the owners manual for your specific model and make
Oct 23, 2009 | Basic Remote Vehicle Alarm System
We live in Phoenix Az. We have a 2005 Honda Accord 4dr LX 4 cyl, automatic, AC with factory alarm. The alarm goes off "at will" when parked at home, in parking lots or wherever. It just went off when a...
do you have a remote for alarm? if yes adjust sensitivity with remote push to arm and hold. if you have a sensor under the hood adjust screw on top of sensor.
Jul 22, 2009 | Honda Accord Cars & Trucks
Alarm sounds for no reason
sensitivity adjustment on alarm module needs adjusting to desired sensitivity
Jul 04, 2009 | 2002 Volkswagen Beetle Turbo S
Basic Remote Vehicle Alarm System Logo
976 people viewed this question
Top Bulldog Vehicle Parts & Accessories Experts
john h
DrBogo
Level 1 Expert
vtec
Are you a Bulldog Vehicle Part and Accessory Expert? Answer questions, earn points and help others
