Question about Maxtor Hard Drive
Maxtor 4d040h2 hard drive circuit board.... where can i get one???? a good websight where i can find some would be great where i can get one cheap something reliable looking i would like to avoid buying a new one if at all posible
  • 5,660 Answers
You can also borrow one of out this harddrive,
http://www.geeks.com/details.asp?invtid=4D040H2-R&cat=HDD&cpc=JAD, then after you retrieve your information from the Maxtor with the circuit board problem, use this harddrive as a second harddrive.
Posted on Sep 09, 2009
Testimonial: "great work"
    Brigadier General:
  • 5,158 Answers
Ebay, i have seen them on sale there before
Testimonial: "great thank you"
How does a 2013 iMac recognize an IDE Maxtor 4d040h2 hard drive in a Sabrent external usb enclosure?
Use Disk Utility program to get the details of the drive on USB Port.
Located in Applications / Utilities.
This offers general First Aid for the drive.
This Disk Utility can also Format a drive & Partition it. Which will ERASE everything!
For reliability....
TEST the drive selecting a One Pass Security Erase which takes a lot longer but thoroughly checks all sectors for bad areas.
TJ
Sep 10, 2014 | Maxtor Computers & Internet
I-series enclosure won't work properly with maxtor 4D040H2
I have two suggestions.
  • First check and clean your connections.
  • Update your drivers by CLICKING HERE.
  • Lastly, let Microsoft scan your operating system and fix, if necessary, any problems in three easy clicks. CLICK HERE
Apr 29, 2012 | Maxtor Hard Drive
Maxtor 4D040H2 HARD DRIVE HDD IS CLICKING
Hard drives do make some sounds when they run.
If the drive is in warranty, take it back to the store.
If it isn't, there is NOTHING that you can do without a clean room. Use it 'till it breaks.
Mar 22, 2010 | Maxtor Computers & Internet
I'm getting a code 10; cannot start device on my maxtor 3200 . The power light is on, but it no longer functions.
What is wrong with your drive is probably what was wrong with my drive. After two whole days of gut wrenching about should I or shouldnt I take the darn box apart , I took it apart figuring well it is a code 10 and Seagate ( bought maxtor) tells you that the drive has probably failed.
I took mine apart and found a printed circuit board that was attached to a standard IDE drive. I took the board off and plugged the now IDE drive into a spare IDE cable and power connection, turned on my computer and crossed my fingers. Lo and Behold the "CODE 10" DEAD HARDDRIVE WAS ALIVE!!! my guess is that the circuit boards overheat as their are very little air flow slots for this drive and something lets go between the hard drive and the connections. So dont throw it away , carefully pry open the plastic case and remove the hard drive and the printed circuit board ( you have to unscrew the metal cage around both and take out the 3 screws in the printed circuit board. then carefully separate the board from the hard drive . At least you should be able to recover your data on the hard drive. I ran a quality test on the hard drive after I copied all the files from it and there is not one sector wrong on the whole drive. This may not be the solution you are looking for but in the least you are not throwing away a possibly good hard drive. Patience is the rule in prying the case open ( I did it with two medium screwdrivers and started at the hole in the case near the connectors that is rectangular in shape. I too had the lights are on but nobody's home syndrome. Good luck
Aug 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Need help on how to attach jumpers on Maxtor Hard Drive Model # 4D040H2
It is in my experience with hard drives used in external USB enclosures - the jumpers are not nessessery.
Jul 04, 2008 | Maxtor Hard Drive
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
Hard drive
If you can find another working 6L300RO, you can try swapping the logic board from the working drive onto the dead one. Try this if all you want is to recover the data from the dead drive.
Jan 15, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Maxtor 4R120L and Maxtor 4R160L
It is possible to replace/transplant the circuit board. But I am not sure of the motor and the platters. I would suggest you not to play around with the platters. If you wish to replace the circuit board (I guess it is also called the logic card) get a hdd of the same make and size and replace it with this one.
Nov 09, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
426 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
