Question about Lexmark X4270 All-In-One InkJet Printer
Error 1200 on my lexmark 4273 fax machine - Lexmark X4270 All-In-One InkJet Printer
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Displaying "Error 1200" on my lexmark x4270. How do I fix it?
This error is too complicated to explain using text, so will refer you to a Lexmark support document for your error and model:
Lexmark X4270 Error 1200
Jan 14, 2010 | Lexmark X4270 All-in-One Multifunction...
Keep showing Error 1200 when trying to rec a fax? What do i do too correct the problem.
Not a fax problem, but your X4270 is having difficulty with its carriage. Try this solution from Lexmark:
Jan 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error#1200
can i have a solution to this problem? thanks!!!!!!!!!!
Nov 26, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X4270 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
