Question about Frigidaire GLTF2940ES Front Load Washer
Frigidare galllery series washer when i wash sometimes it wont spin and it says E10
    President:
  • 744 Answers
Hello, The E10 error code indicates there is no cold water coming into the machine, either this is because the inlet valve is bad or there is a kink in the cold water line or a blockage in the filter screen where the cold hose hooks up to the machine or one of the kids turned the cold water off at the back of the machine :) Either way you should check everything I have listed, If you can't find a blockage replace the inlet valve. If you have any questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Sep 09, 2009
Washing maching wont spin out comes up e10
Hi Noeline, this is JK. Thank you for your post. I understand that you are receiving error E10 on your washer. This error means that the fill time is too long. Make sure that the washer has adequate water supply, check the faucets to make sure they are fully open on both hot and cold and make sure that the water pressure is above 30 psi. If these suggestions pan out there could be something going on with the pressure switch/sensor, main control board or the inlet valve assembly and may require a professional to diagnose.
Hope this helps!
Mar 11, 2014 | Electrolux Washing Machines
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer is showing a code
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Front Load washer with error code E10, stops before spin
10E on electrolux means water hasnt emptied before max empting time,(drain problem)it wont spin because of this,this could be the same situation even though its a frigidaire
May 07, 2009 | Frigidaire Washing Machines
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Error E10
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on SEARCH
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
STEP 6 Also access and save, or print PDF files: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, OPERATING INSTRUCTIONS, and PARTS MANUAL(These PDF files will help in replacing, repairing, and maintaining your machine.)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
May 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidare front load washer
check to make sure you have removed all the shipping braces
Mar 02, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
96 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
