Question about Belkin Wireless Cable/DSL Gateway Router
No internet connection
Using BELKIN WIRELESS ROUTER B, MODEL:F5D6231-4, for most of times it work properly,but there are times that the signal from the modem doesn't get bridge to thee computer. as a stand alone (moden to computer) the signal is okey. The isp sugest that the problem is in the router that is doing resets. wen I try to access the router config. with my brouser (win.internet exporer 7) it always said that the page can't be displyed offline. I'am stock pls.help.
  • 41 Answers
Tobe honest try to uninstall internet explorer 7
Posted on Dec 10, 2007
Router connection
The problem is not the antenna.
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 13, 2012 | Computers & Internet
My wireless router modem wireless signal keep disconnecting
Assuming it has been running well in the past, it is likely there is some interference coming from another wireless source, most likely a cordless phone that you may have recently acquired.
Try to re-initialise the modem and see if there is any difference.
Apr 18, 2011 | Belkin (F5D6230-3) Wireless Router
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
http://www.belkin.com/
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Laptop and iPhones cannot connect to my network unless they are i
hi! I will be more than glad to help u in this concern..your using a wireless n router and the n router will work with the signal properly if u are using a wireless n network adapter. If you are using a wireless g adapter then u need to use a wireless n range expander in order for the other wireless g adapter to get good signal..or try buying a antena which 9 dbi which will boost the signal from your wireless g adapter..
Aug 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Cable/DSL Gateway Router Logo
81 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
