Question about HP Officejet 5510 All-In-One Thermal Printer
Too much red in picture and cannot make copy
Trying to print pictures but too much red and grainy .
Try to make a copy on printer and sheet comes out blank
The pictures on my printer comes out too dark
Are you Copying (Using the scanner) pictures or Printing them?
Is the printer Monochrome or Colour?
Is the printer Ink or Laser?
Are you trying to print Photos or just Pictures like Clipart?
What software package are you using to print these pictures?
Sep 12, 2014 | Office Equipment & Supplies
I have printed 4 pictures on 1 sheet. faint black lines and a red tinge on a portion of the pictures.
try performing the cartridge cleaning procedure outline in you user manual about 4 to 5 times. Try cleaning the print head by removing the cartridges with alcohol and a lint freee cloth.
Feb 19, 2011 | Lexmark X75 All-In-One InkJet Printer
Tried solution to change to USB Cable. Replaced alll ink cartridges. Photos still wont print. Coming out grainy and with white lines all overthe picture no matter what source I print from.
Hello;
This mostly occurs due to some paper quality.
* Try replacing some different Quality of papers
* Try cleaning the Heads of the printer through the maintainece software provided by canon.
Nov 03, 2010 | Cannon MULTIPASS C530 Printer
What image resolution should i be using for regular 4x6 prints i have a 10.1 megapixel camera, but my pics still look grainy
Your pictures should not be looking grainy. Are they printed grainy but look clear on your screen. If so then it's just your printer. Try forcing the flash in the highest resolution. If you video's are grainy too then there is possibly something wrong with your camera. Make sure your lens is really clean. Worst case your CCD sensor inside your camera could be bad. Hope not!
Sep 20, 2010 | Casio EX-Z1050 Digital Camera
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
I have been trying to get my 5300 kodsk printer to
Try to print a picture in from the computer if it works then the printhead needs replacement (Call Kodak support).
If while printing picture still a black sheet is thrown out. Delete the Kodak printer icon from control panel > Printer and faxes . Restart the computer and re-connect the USB.
If these does'nt work try to COPY a pictue using only the printer, still u get a blank page try to install the ink cartridges and the printhead. Is still blank prints. The printer will be replaced
Jan 21, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
WHEN PRINTING PICTURES THEY ARE RED
make sure that the cartrdiges are properly installed
use the clean ink cartridge utility provided in the printer drivers
try checking the printer drivers.
depending on the printer you may print the alignment sheet to check if all the colors come out properly.
Jul 14, 2009 | Office Equipment & Supplies
How can I print more than one picture on a sheet? I have a Cannon Pixma MP 830 .
If you want to maintain the quality of the pictures, you should get a picture handling program like Corel Photo Album. There are always sales on the software and on sale it's not very expensive. If you are just printing web pictures, you could copy the pictures (.jpg format works best) you want to print into a word processing document, scale and arrange them and print them.
Corel Photo Album works wonderfully with Canon printers and you have innumerable options plus scrapbooking your pictures.
Apr 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing pictures
If your normal print looks OK, make sure that you are printing your pictures on the correct side of the photo paper. Most photo paper will only print properly on one side. If you print on the other side, the image looks very grainy and faded, and the ink will still be quite wet when it comes out of the printer.
Jun 12, 2008 | Canon PIXMA MP470 All-in-One Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
