Question about Kitchen Ranges
Clock and oven do not work - Kitchen Ranges
  • 11,896 Answers
I suggest testing the power supply to see if there is any voltage coming out of it. See if the fuse is blown. There should be thin wire inside glass tube that runs all the way across the tube. If not, is should be replaced.
Posted on Sep 09, 2009
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Feb 23, 2011 | Stoves Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
Simpson Atlas Apollo ceramic top stove, Digital clock etc. Just installed. No user guide to set clock etc. Oven wont work, suspect clock needs setting. Can I get a user guide?
Hello, I think I have the same oven as you, and yes the oven doesn't seem to work unless the clock has been set.
On my oven, there are 4 buttons and a dial below the digital clock.
To set the clock, you need to turn the dial whilst holding any two of the 4 buttons down.
For me it's a two handed job.
Cheers,
Michael
Nov 30, 2008 | Kitchen Ranges
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
