Question about GE Profile Harmony DPGT750EC Electric Dryer
Blower Sometimes our blower works and other times it will not unless I unplug the dryer for a while or let it set for a bit and then it will blow for a short period of time again. What can be the cause and how do we get it fixed? Dan
  • 625 Answers
The internal thermal overload is tripping out. check your motor bearings for no lubrication. there might be a build-up of lint inside the end bells of the motor that contribute to the overloading condition
Posted on Dec 15, 2007
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
Ac/heater blower motor fluxuates in speeds blows vary slow then quits!
has a short and needs to be cleaned you can buy canned air at wal-mart to try first
Jun 15, 2012 | 1996 GMC Jimmy
1996 Ford Thunderbird LX - AC/Heating A few months back I had my AC recharged (At the time my heating still worked) and it worked fine for awhile, but about a month after that I would turn the defrost...
I'm afraid you have the deluxe system,my friend. It has 2 electronic circuit boards that may be going bad. Very expensive unless you can find used or aftermarket.
I hope it's just the blower motor, but I had the other thing happen and I had to wire around it,losing my AUTO temp and blower control. don-ohio
Mar 26, 2017 | 1996 Ford Thunderbird LX
My 1998 Buick Lesabre Custom's fan blower doesn't work consistently. Sometimes it'll work, sometimes it doesn't. Sometimes it comes on right when I turn on the car, sometimes it'll come on down the road...
you need to replace the blower motor resister. on the inside, passenger side glovebox area or near the center. really easy to do. unplug the wires and take out a couple of screws, its that simple
Jan 10, 2011 | 1998 Buick LeSabre
Air conditioning and blowers not working, fuse blows immediatley after changing. there was a clicking noise heard before fuse blew. No display on dash unit. (2000 passat 1.9TDi Sport)
Try unplugging the blower resistor, located under the passenger side, under dash area, put a new fuse in and see if the fuse opens (blows). If it does not blow then unplug the blower located in roughly the same are and plug the resistor back in if it blows then it the resistor if not it's most likely the blower motor.
If the fuse blows when both resistor and the motor is unplugged the you need to unplug the a/c head unit and see if it still blows(open fuse)
Hope this helps
Mar 17, 2010 | Volkswagen Passat Cars & Trucks
I have a maytag ldg8200aaw gas dryer. it works and will dry clothes well but makes an extremely loud grinding noise as the drum turns...sometimes it even seems as if it is not engaging...I am trying to...
Your dryer is definitely worth fixing. The blower wheel is plastic 53-0106, These will wear out and get loose. Make noise and the clothes take a long time to dry. Repair Photosa9a0520.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 10, 2010 | Dryers
Maytag Bravos dryer heats but does not blow air out the vent.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Jan 11, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
The dryer heats up right away then cools off. Takes a long time to dry.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Nov 26, 2009 | Roper RGX4634KQ Gas Dryer
I turn the the fan on for the heating but the fan
Sounds like a seized up (bad bearings) blower motor. It may not pull enough current to blow the fuse at the lower fan settings but does at the high one. Something could also be jamming the blower fan in its air duct.
Most blower motors can be accessed under the hood. Replace the fuse then put the blower switch on one of the lower settings (don't blow the fuse). Get yourself a good sized screwdriver and hit the back of the blower motor with the screwdriver handle a couple of times.
Sometimes (unless the blower motor has totally seized up) you can get it to spin and this will tell you for sure you need a new blower. Other than that, you can get a spare blower motor, remove the connection wires from the old motor and hook them up to the new one to test before you go to the trouble of replacing the blower.
Hope this helps you out... -Dan
Oct 14, 2009 | 2000 Ford Focus
GE Profile Harmony DPGT750EC Electric Dryer Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
