Question about Canon imageRUNNER 5570 Copier
Ir6570 with e000100-001 error
This has me completely stumped - We have changed dc controller, fuser, fuser assembly tray, fuser plug in and HV pwoer supply. Nothing gets the error reset. While looking at the fuser temp. We notice the fuser never gets above 120.
  • 168 Answers
If you reading it right on the screen an e 000100 is a laser failure it also happens on this model if you run it with the toner assy out of position
Posted on Sep 10, 2009
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
Error 54.16 laserjat 3600
Hi
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
1. Que Make sure connector J1020 on the
DC controller is seated Correctly.
2. Replace the DC controller.
Dec 05, 2013 | HEWLETT-PACKARD Hewlett Packard Genuine HP...
HI I M KAMRAN I HAVE CLJ5550N PRINTER ERROR ARE COME 59.30 I REPLACE TRANSFER KIT BUT ERROR STILL 59.30
Hello ,pls check as describe,
Reconnect the connectors J18 for
the fuser motor and J1101 on the
DC controller PCB. Replace any
damaged parts.
2 Replace the fuser drive assembly.
3 Replace the DC controller PCB.
Calibrate the printer after replacing
the DC controller.
Mar 22, 2011 | HP Color LaserJet 5500 Printer
59.30 printer error Do I need to replace a Fuser drive assembly?
Manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damaged parts.
2. Replace the fuser drive assembly.
3. Replace the DC controller PCB and recalibrate
So yes I think you do
Jan 14, 2011 | HP LaserJet 4600dn Color Printer
I have problem canon ir6570 e025-003?please help me,
This is an error code for the connection of the toner bottle motor at power up is not detected. Did you recently ahve the hopper assembly off? Maybe this connection was forgotten. Check. The motor itself may have to be replaced.
Nov 01, 2010 | Canon imageRUNNER 5570 Copier
Marca error 60,02
60.2
The tray 2 lifter-motor is not functioning.
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
Hp clj 4700n 59.30 error
The error stands for:
59.XY PRINTER ERROR
X is in your case 3 : FUSER MOTOR STARTUP ERROR.
Y is in your case 0 : NO COLOR
The service manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damged parts.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Best regards,
mannu_rakesh
Aug 22, 2009 | HP LaserJet 4700 Printer
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Canon imageRUNNER 5570 Copier Logo
709 people viewed this question
old marine
old marine
