Question about Onkyo DR90
Dvd just keeps spinning making grinding noise, player just says loading
  • 636 Answers
I would unplug the unit and take the cover off, sounds like it could use a good cleaning, you can also lubricate moving components with Vaseline. Reverse the vacuum and blow excess dust from the unit, locate the laser lens and clean with alcohol and dry with a cotton cloth.
Hopefully this resolves your issue.
Posted on Sep 09, 2009
4 Suggested Answers
  • 289 Answers
SOURCE: loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Posted on Feb 07, 2009
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
toy_ladi
  • 484 Answers
SOURCE: My Akai dvd player shows
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Posted on Jun 14, 2010
RCA TV DVD Combo DVD makes loud grinding noise when playing DVD
does not sound correct. Perhaps the laser is hitting the DVD, or a gear is dirty. Anyway, if you keep playing with a strange noise in the player, it won't take long before it stops complete, or till you destroyed all your DVD's When you don't see scratches on the silver side of the DVD's, you should check (or let a technician check) what can be wrong with the player.
Sep 30, 2014 | Televison & Video
I have a Sanyo DWM-400 it is a year old Rarely used... now allof a sudden it makes a strange grinding type noise and does not load movie... What is wrong and how do I fix it???
Might have a loose or broken plastic parts or a spinning motor is missing the gears of the machine device.Tries take the device hold it tight lift it over ur head shakes it a few times.That the easiest way to fixed grinding noises.
Mar 16, 2011 | Sanyo DWM400 DVD Player
PVS3393 - We were traveling in the car and the dvd was playing fine, then skipped then came to a halt. I restarted it and the dvd would only spin and the screen said it is loading but it continued to...
sounds like your lens has become unseeded and will need to be adjusted this can be done by opening it and seeing where exactly it is missing support however i would suggest purchasing a new one and returning this old one
Oct 27, 2010 | Audiovox PVS3393 9 in. Portable DVD Player
Player makes lots of noise when trying to load a disk, some what of a grinding sound and eventually stops with the disk not loaded
hello,
there seem to be a problem with the lens of the dvd player so it is not accepting the disc that is why it is making that grinding sound.
the lens could either be weak or dirty.
try use a lens cleaner, if it works after then it means the lens was dirty.
and if it does not work, then it means the lens is weak and needs replacement.
take care
May 30, 2010 | Denon DVD-2800 DVD Player
Loud mechanical noises from my dvd player during loading,advcing,
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
DvD player wont load
The grinding could be the laser trying to read, so you could try a CD/DVD cleaner product> It also could be the laser is off track or damaged and you would need to have it repaired or buy a new player.
Mar 18, 2008 | Televison & Video
Loud grinding, spinning noise with game in console.
Even if it is still playing dvds it might be the dvd-rom drive, usally it spins a game faster than a dvd. Or it could be the harddrive if it was trying to save something. try to download a demo or something to check the hard drive.
Mar 17, 2008 | Microsoft Xbox 360 Console
Error message
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Symphonic WF803 DVD Player/VCR
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
Spindle makes sounds and seems to grind and unable to read discs
i did notice inthese models there is a ribbon and for some reason the ribbon will hit the dvd making a noise..push it down it will scrach your dvd
Oct 19, 2007 | Coby DVD-206
Open Questions:
Onkyo DR90 Logo
1,086 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
