I have a Akai GX-635D it don't sound to good what
I have a Akai GX-635D it don't sound to good I clean the head what can I do to fix it so it could sound better . Also I have Teac EE X300R and it play's but it stop when it get halfway on the tape and it come a Full Stop can you tell me what can I do to fix it. I want to Thank you for Technical Support... Do you know there I could take him to fix in FLorida around jacksonville or Orlando area. I live in between Jackson and Orlando.
  • 319 Answers
SOURCE: akai gx 747 dbx reel to reel need repair and service zip 95624
What problem(s) are you having with unit?
Posted on Apr 23, 2008
SOURCE: Akai Gx-77 reel to reel tape dech
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Posted on Jul 31, 2008
  • 319 Answers
SOURCE: Akai gx-77 real to reel
Mechanism is in need of major cleanning and lubrication. You might also consider replacing belts and rubber pulleys
Posted on Aug 03, 2008
test
Posted on Oct 27, 2008
Grubhead
  • 5487 Answers
SOURCE: My AKAI GX 636 records but can't hear anything on playback
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Posted on Aug 06, 2009
Akai GX-77 isn't erasing the old music on a new recording. Can hear the old music on the new recording. Please help. Thanks
Akai or Sony- just problem with erasing head. Usually erasing head looks like black and smoller near reading head. Can be problem deeper inside 'Tape Decks'- wire, no signal to the head and etc.
Oct 13, 2016 | Audio Players & Recorders
Gx 635d-recording only on one channel
This is very common due to the cheap transistors they used as well as a possible bad electrolytic cap.
Apr 06, 2014 | Audio Players & Recorders
How can I remove the pinch wheel from akai gx260d
I am no expert in Akai units but the GX-635D I was working on had a screw off cap and then there was a nut that unscrewed to get the Pinch Roller off. That is all I can say as far as help- the cap should unscrew counter clock wise.
Jan 19, 2013 | Audio Players & Recorders
I have a akai gx -635d reel to reel tape player that has stop playing where can i get it fix near me in lafayette,ala 36862
Fuses blow when there's an overload. In your case it will be a transistor perhaps in the power supply that has shorted out. It should be easy to find with an Ohm meter as it will act like you have just touched the two probes together when it's placed on the terminals of a suspect transistor.
May 08, 2012 | Audio Players & Recorders
Have Akai GX 630 D Reel2Reel, left channel sounds dull.
THis problem could be due to heads not being clean, CLEAN, or tape head alignment needs checking. test playback with a tape you KNOW to play well on another machine...demagnetizing can also improve play and record performance. A damaged tape guide post could also be the problem but this is not likely. Lift up the hinged head cover and using a flashlight and a mirror ensure that all three heads are CLEAN and shiny...clean guide posts too. test play with a tape known to be good.
Feb 27, 2010 | Audio Players & Recorders
Akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Aug 26, 2009 | Audio Players & Recorders
Jul 12, 2008 | Audio Players & Recorders
Unable to record with Akai GX-77
Make sure the cassett you are using has safety tab intact. Clean the heads and tape drive roller. If unit has a record level control, make sure it is set correctly
Apr 07, 2008 | Audio Players & Recorders
169 people viewed this question
 Grubhead
Grubhead
