Question about Maytag Dishwashers
I have a Maytag Jetclean Dishwsher EQ Plus, Model # MDBD880AWQ. The door won't close completely and latch. The racks are not in the way
  • rsorn May 11, 2010
    Let me see if I got this right. For your experts to solve my problem it will cost me $9.99. However, if I solved this problem myself, you want me to tell you how I did it. (for FREE) I DON'T THINK SO. I cant believe you have the balls to even ask me this.
I have the same issue. I need to put full weight on door to get the dishwasher to go. The tongue (on the top of inside) is fine. The problem is in the latch. Looks like I need to take the door apart and get a new latch. I am guessing you have to remove the 8 (?) allen screws on the inside of the door and take a look. Good luck. I will tell you how I do. Post back if you have it figured out.
Posted on Oct 01, 2009
Maytag jetclean dishwasher eq plus
What is the model number?
May 21, 2013 | Dishwashers
How do I replace myself the detergent/rince aid assembly on a Maytag Jetclean dishwasher EQ plus model #MDB9150WB? I only need to replace the door, but I don't see a part for that, just the entire...
Carol,
This is a simple repair. Remove the screws around the outer door edge and separate the door. The dispenser is clipped into position with several screws. Remove the screws and push the dispenser through the door.You can purchase the part from the link below.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Our Maytag Jetclean Dishwasher EQ Plus will not turn on (MDB9150AWS) and we cannot find a repair manual to troubleshoot through the problem. Maytag does not offer repair manuals on this model. Any...
Try this. From what I have found Maytag discontinued the Repair manual but it appears that all MDB and MDC models fell under this one repair manual.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47135
Oct 10, 2009 | Dishwashers
Would like to change the white dishwasher door to stainless.
Sure is. As long as the door is same size and same button options and you can get it to latch on, then no problem. I have seen others do it. You can always check out repairclinic.com to see if they have the door.
Aug 05, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
228 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
