Question about Epson Stylus CX3810 All-In-One InkJet Printer
Paper Jam - No Paper Entry
The paper doesn't go in. The error that pops up from the system tray is 'Paper Jam' when there is not paper in the printer. Ive tried forcing down a a piece of cardboard down the throat of the paper but does'nt work. With regards to the second solution, I don't know how to 'get to' the rubber rollers.
If somebody has either a solution that I can implement or I can show it to somebody that would be great.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Epson Stylus  CX3810 All-In-One InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
