Question about RTO Atwood Water Heater - 6 Gal LP
Atwood GC6AA-9E water heater isnt working properly
Atwood GC6AA-9E water heater for my camper is not working properly. It will not spark on its own but even when i use a bbq lighter it will turn the flame on for about 5 seconds then it will turn off and shut down again. What could be the problem?
  • John Coristine
    John Coristine May 11, 2010
    IS IT A DSI HEATER? IS THERE LP TO HEATER? IS THE LP PRESSURE GOOD? HAVE YOU HAD THE THERMOCOUPLE CHECKED AT A "GOOD" RV DEALER.
  • RTO Master
  • 6,674 Answers
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Posted on May 26, 2010
My hot water keeps shutting off after I start it. It runs like 15-30 seconds. What's up?
Sometimes that will happen if there is not enough (or any) water in the tank. Also, there might be a little air in the water line(s) if you had the thing apart. Keep trying. Good luck.
Jan 24, 2018 | Water Water Heaters
HI I HAVE AN ATWOOD WATER HEATER MODEL NUMBER GC6AA-9E AND AS HARD AS I TRY, I CAN NOT GET AN ANWSER FOR THE RIGHT REPLACEMENT MODEL. THERE IS CONFUSEION ON WHAT WILL WORK. YOUR ASSISTENCE WILL BE...
By model number it tells me that you have Electric element, as well as gas with electronic ignition for the gas, is that correct?
Any 6 gallon Atwood will work, and if you want to have all the same features available, you simply order another 6 gal, with same features. If you decide to forget the electric element, and just go with gas and electronic ignition, they should be able to order you just that tank. You can even order a tank with manual ignition, and forget all the other options if you wanted to. Personally, if it's got hydro and electronic ignition for gas, I'd replace it with same, unless I have no access to hydro, and will never use that option. If all those options are working on yours, you can just replace the tank, rather than buy all those items new on a complete tank. Any 6 gal. Atwood will go in the hole, it just depends on what you decide you want. I don't understand what the confusion is about, but maybe I'm missing something here.
Oct 02, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have atwood GC6aa-9e, will not fire the ignition tries 3 sets
Have you tried temporarily removing the thermal cut-out from the circuit to see if ignites then? It's the little resistor looking thing inside the plastic sleeve/cover that runs to thermostat. Disconnect it from the thermostat terminal, and from wire that is on the other end, and you should be left with a female spade connector at end of that wire. Connect that directly to thermostat terminal where the other part was connected, and try it. If it works, the thermal cut out is no good and needs to be replaced for safety reasons, in case of flame out of control, it blows and shuts gas valve off.
Jun 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a GC6AA-9E and the Pop off valve lifted and sprayed all the electrical components and now the igniter will not spark. Any ideas where is the best place to start troubleshooting the controls.
Look for the little round temp switch inside little plastic sleeve, below pressure relief valve . Look where is plugs into at both ends carefully. Now disconnect it (take it out of the circuit) and hook the one end, to terminal where other end went to. Now try it.
Jan 04, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have model gc6aa-9e water heater. I think i blew the 120 element by turning on breaker B4 filling water tank after winter; The schmatic that came with camper shows part # 91160. Is this corect and if so...
Yes, That will do it. Most RV appliance parts can be purchase at RV dealerships that have parts department. Camping world has always been very helpful. As far as A part # is concerned I can't confirm although it is good to have it and the make and model of the unit. Good Luck
May 08, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood Water Heater - 6 Gal LP Logo
1,082 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
