Question about Canon PowerShot S5 IS Digital Camera
I turned on powershot then opened the battery
I turned on my powershot then opened the battery cover to take out the SD card without turning it off. The camera turned off with the lens still extended and won't turn back on. What do I do?
  • 57 Answers
If you install fresh batteries, close the battery door the lens should retract. If it did not, make sure the batteries installed are properly. And don't do that again you will lose all pictures on the card and may ruin the card permenently.
Posted on Sep 09, 2009
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
My canon g9 lens will only come out quarter the way turn on and then go back in and tirn off. It is over 2 years old.
check your battery for full charge, pull out the battery and ckeck if theres moisture keep camera in a dry warm place for some time;
keep camera without sd card and battery for sometime.
all should be well
Aug 15, 2010 | Canon PowerShot G9 Digital Camera
My canon powershot sd 1200 wont turn on i have recharged the battery. what else can i try?
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Jun 01, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
SD card slot/battery cover broke
Ebay, Canon, Amazon.com, Tigerdirect.com
Dec 25, 2009 | Canon PowerShot SD600 Digital Camera
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Dec 22, 2009 | Canon Powershot SX110 IS Digital Camera...
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
Turn the Canon Powershot A560 over so the bottom is facing up.
Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
5
Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
6
Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
7
Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
8
Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
SD 1100
Hey ceedub,
According to the manufacturer if the lens won't retract back into the camera it is caused by the memory card slot/battery cover was opened when the power was on. If this is the case to fix this you should close the memory card slot/battery cover, and then turn the camera on and off. If this is not the cause there is most likely something obstructing the movement of the lens (i.e. sand), and I would try blowing compressed air into the side of the lens to try and dislodge whatever it is. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Canon PowerShot SD1000 Digital Camera
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon PowerShot S5 IS Digital Camera Logo
503 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
