Question about True 12 cu. ft. / 340 liter Commercial Freezer TUC-48F
TUC-48F undercounter -10 freezer, door heaters not heating
TUC-48F under counter -10 freezer, door heaters not heating. Ice builds up and holds doors open creating more ice holding doors open more.
Need a schematic for the heated door surface or exploded view of the heated door area.
  • True Master
  • 1,147 Answers
Http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
Go to this True web site. It has spec sheets and manuals. Hope this helps you
Posted on Sep 11, 2009
Ice freezing up on the evaporator
If the unit is equipped with 'auto-defrost' the defrost heater or its timer has failed.
Another possibility is a bad door seal.
Mar 12, 2015 | Electrolux "15"" Under-Counter Ice Maker"
No door heat
The Mulluen heaters will be Built into the frame not in the door.
Mar 27, 2014 | True Freezers
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Icing on door gap
Hello Sonny;
My name is Peter. I am a retired field service refrigeration technician.
I work on household refrigerators and freezers. Your situation is no different.
Freezer doors will ice up if there is a gap. The warm surrounding air will cause condensate and icing at any air gap; "hot goes to cold like a magnet".
You freezer door gasket needs to be reconditioned or replaced. You door may be misaligned and needs to be realigned. Your door frame may not be flat and needs to be flexed. Call me.
Glen Burnie, MD
443-306-1362
Aug 12, 2013 | True Refrigeration True TWT-48F 48"...
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Door jam icing up
door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
May 24, 2010 | True 72 cu. ft. / 2039 liter Commercial...
3-door undercounter refrigertor worktop surface
the coils that deliver the cold air are building up condensation. anything that gets cold in the outside should be insulated so as to reduce condensation. hope this helps
Sep 15, 2009 | Everest Refrigeration Freezers
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
True 12 cu. ft. / 340 liter Commercial Freezer TUC-48F Logo
357 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
