Question about Whirlpool LGB6000KQ Gas Dryer
I have a Whirlpool LGB6000KQ1 Gas Dryer. It
I have a Whirlpool LGB6000KQ1 Gas Dryer. It starts to heat for about 2 minutes then heat turns off. Lint trap and exhaust 100% clear. I believe it could be 1 of 3 parts:
1. (3387134)Thermostat, Internal-Bias
2. (3403140)Thermostat, 205 degree
3. (280010) Kit, Thermal Cut-Off
Any thoughts??
  • jkash76 Sep 26, 2009
    That was the exact problem! My dryer works. $40.00 fix!
    President:
  • 744 Answers
Hello, Unfortunatly your wrong on all 3 counts sorry :) This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils I have a Whirlpool LGB6000KQ1 Gas Dryer.  It - 57d5263.jpgThis The coils are mounted to the gas safty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Sep 09, 2009
Testimonial: "This was the exact problem. My dryer works perfect. It was a $40.00 fix!"
  • Mike Price
    Mike Price Sep 28, 2009
    Your welcome :)
Whirlpool Dryer LGB6000KQ1 - Dryer Doesn't heat nor does timer advance.
Probably the heating element. They go bad more often than timers.
Jul 25, 2017 | Whirlpool Dryers
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
518 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
