Question about 2wire (1000-000057-000) Modem
How do i get the ethernet driver installed on a computer without an internet connected
  • 2wire Master
  • 32,281 Answers
Use a computer that has Internet connection (a friend's) and download the driver, then copy it to a CD or memory stick and take it to your computer and install.
Posted on Sep 09, 2009
What the heck? This is crazy!
You can get a USB to ethernet adapter which will enable you to connect to the internet and download the drivers:
https://www.google.co.uk/#q=usb+to+ethernet+adaptor&hl
=en&newwindow=1&prmd=imvns&source=lnms&tbm=
shop&ei=Va55T57HHtL58QPFgvmdDQ&sa=X&oi=mode_
link&ct=mode&cd=6&ved=0CHYQ_AUoBQ&bav=on.2,or.r_
gc.r_pw.r_qf.,cf.osb&fp=17f151312dece8c7&biw=1344&bih=694
Otherwise, download the drivers using a different PC, save them to a usb stick, plug that into the machine that needs the drivers and install them from the stick.
Apr 02, 2012 | Dell Dimension 2350 PC Desktop
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
My computer doesn't have its pci.sys,#512;Ethernet Controller installed and i can't connect to the internet to update it what do i do?
You will not be able to connect to the internet without the ethernet driver.
To update the driver manually refer to the steps below:
- click start > run then type "devmgmt.msc" - once device manager is open look for network adapters - click the plus sign at the left side then right click on the driver then select update driver online. - it will look for a compatible driver for your LAN card.
hope this helps.
Jul 01, 2011 | Computers & Internet
I have a compaq presario 7478, when I got it, the cpu already had windows xp on it, so I recently reinstalled windows xp, and I can not connect to the internet because I am missing the ethernet controller...
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model computer/laptop and the XP Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 04, 2011 | Compaq Presario 7478 PC Desktop
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
I need to download the ethernet drivers for the computer to detect the modem i cant connect to internet and i would like to know how to install the ethernet drivers without using the internet
If you dont have a manufacturer disk driver cd its difficult
you will need to download it in a cybercafe and load it on the machine
Use driverguide.com to download the driver.
Nov 13, 2009 | Compaq Computers & Internet
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
2wire (1000-000057-000) Modem Logo
114 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
