Question about Dell Latitude X300 Notebook
I need instructions on soldering a dc jack on my latitude x300 laptop
    President:
  • 2,600 Answers
OK the first link is for the DC jack repair and the second link is a service manual for your laptop. Just copy and paste them into the address bar of your browser. Be sure to save a copy for yourself as a reference. Good luck
ParrotHead PC Repair.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/comment-page-9/
http://www.elhvb.com/mobokive/edwin/laptops/Dell/LATITUDE/X300/X300.PDF
Posted on Sep 09, 2009
Dell latitude d510 has no power
Please check out the following steps to confirm the real issue:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
I think the most likely cause is that your dell charger is broken, just try a new charger to test:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Dec 04, 2012 | Dell Latitude D510 Notebook
How to replace dc jack
You'll have to take the laptop apart to fix the DC Power Jack. Most times it is soldered onto the motherboard which means you will have to desolder the old one and solder the new one. Be prepared to spend some time and you have to have the hands of a surgeon or you will damage the motherboard.
May 17, 2012 | Dell Latitude D830 Notebook
Latitude C640 will only run from battery not AC adapter. I have tested the AC adapter on another laptop it works fine, I have taken the laptop apart the solder joints to the plug look fine. I was just...
blubaustin, you are stating you disassembled the laptop, and physically checked each solder joint, for the DC Power Jack?
Do I also assume you checked the condition of the DC Power Jack? None of the three pins wiggle?
This part of the system checked out, I would have to assume it's failure of the Power sensor chipset.
This is not for the Latitude. Just an example of a laptop power sensor (Power I.C.),
http://www.alibaba.com/product-gs/460807218/ATMEGA128L_8AU_IC_AVR_MCU_128K.html
More examples,
http://easycomponents.en.alibaba.com/search/product?IndexArea=product_en&SearchText=laptop+power+ic_lap+top+power+ic&fl=y&d_pid=496042749&d_type=sp
Unsoldering, and soldering is pretty basic.
In the first example above, the top view is how the chipset sits on the motherboard.
With the metal 'legs' down. (Can be called Pins, or Terminals)
Magnification, and a bright light.
Desoldering Braid (Or Desoldering Tool)
Pencil tip 20 to 35 Watt soldering iron.
Small utility brush to clean the surface after unsoldering, along with Isopropyl Alcohol. (91 percent is best)
Soldering Stand with sponge
.030 Rosin Core solder
CAUTION!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with NO sparks or flames present.
If the chipset is not available, and/or the skills are not present, then I suggest motherboard replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 26, 2011 | Dell Latitude C640 Notebook
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
Need instructions on how to replace dc jack on everex stepnote 4101m
- remove mobo from laptop
- use hot working station (like Aoyue 852) for a long time until you can remove the broken DC-jacket
- clean the mobo
- solder the new DC-jacket on the mobo
- clean the residues of solder from the mobo
- put back the mobo in the laptop
- Done.
Jul 26, 2011 | Everex StepNote® VA4103M PC Notebook
I have a latitude d620 i purchased used a couple of years ago. recently, my battery charger light has not been lighting unless i giggle the battery charger body. this has worked and the battery icon on...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 22, 2010 | Dell Latitude D600 Notebook
My Dell Latitude D810 won't even start up. All I have is the bluetooth light. Can you please help?
5. The power button could be bad.
Sep 11, 2010 | Dell Latitude D810 Notebook
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
How do I access the DC Power Jack on a Dell Latitude C510?
I assume you mean to replace it. You need to take all the screws out of the bottom,check under the battery too. Remove the hard drive,keyboard bezel keyboard, Remove all the screws under the keyboard except the cpu heat sink. Seperate the halfs & you should be able to remove the board. Now you can solder a new jack in. Good luck!
Mar 15, 2010 | Dell Latitude C510 Notebook
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
Dell Latitude X300 Notebook Logo
366 people viewed this question
Alun Cox
