Question about Amana 3.2 cu. ft. Top-Load Washer
Amana washer will not agitate or spin. The motor hums. What can I check?
  • Amana Master
  • 8,220 Answers
My Amana Tandem 7300 front load washer gives an f5 e3 code. It would start spin once then stop and make a click/buzz noise then beep three times then shut off. The door latch mechanism was replaced, ...
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Feb 28, 2015 | Amana Washing Machines
My Amana NTW4600YQ fills but wont wash
No agitation or spin? try these:
Jul 12, 2014 | Amana NTW4600YQ NTW4600YQ 3.4 cu. ft. Top...
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
Jan 19, 2014 | Amana NTW5400TQ Top Load Washer
Washer will not agitate or spin
If the unit hums and sounds like it's running but doesn't spin or agitate you've probably got a bad coupler. Open the unit and take the pump and motor off and see if the coupler is broken or missing (This is most often a plastic/rubber part which usually breaks down into three pieces and hooks your transmission to your motor). If it is missing or damaged, replace it. Good luck.
Apr 06, 2011 | Amana ALW480DA Top Load Washer
Will not agitate
your transmission is locked up.
May 20, 2010 | Amana DLW330RA Top Load Washer
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Jul 07, 2009 | Amana ALW895 Top Load Washer
Washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Apr 30, 2009 | Amana NTW5100TQ Top Load Washer
Amana washer not agitating and does not spin all the time
"Its not spinning well" that means it is spinning but at a relatively low speed .....if this is so try having the motor serviced.....or replaced.......also have the capacitor checked...
Nov 10, 2008 | Maytag PAV2300 Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
320 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
