Question about Logitech LX700 - Cordless Keyboard and Rechargeable Optical Mouse (LOGLX700)
My Mouse My light on my mouse does not light up when put on the charger is this because it's charged or is it suppose to come on anyway?
  • 27 Answers
SOURCE: flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Posted on Jul 25, 2007
SOURCE: Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
Posted on Sep 11, 2007
  • 36 Answers
SOURCE: Logitech MX700 optical mouse
-Refurbs usually come barebone, on any refurb product, definately read the terms and agreements of the warranty... No way in $*%# would I take a refurb without SOME sort of defective warranty.
-Try another computer -If it don't work on yours, try it on another one. Ensure its not lose, so wiggle it a little, and if it lights up to charge for a second, there's something interfering with the connection from the mouse to the dock. If all else fails, call the seller, cus it is, a refurb.
-Manuals are downloadable from the manufacturers website. Its a common trend that the manuals are links somewhere around the driver webpage, but a big company like logitech, shouldnt be hard to navigate.
Posted on Dec 28, 2007
SOURCE: Mouse blinks red even when it's placed in the charger
Posted on Sep 15, 2008
  • 62 Answers
SOURCE: logitech mx lazer cordless rechargable mouse
You are welcome. Just make sure to rate this issue to close it.
Have a nice day.
Posted on Jan 09, 2009
SOURCE: mouse
I cleaned the terminals on the charger and the mouse using a little rubbing alcohol. This solved the problem right away.
Posted on Jan 12, 2009
0 characters
1 Points
New batteries in mouse, but red light still blinking. even after putting in charger overnight.
Clean the contacts on the charging station and the mouse itself with some alcohol. Most probably they are oxidized and your mouse just sits there not charging.
Mar 08, 2011 | Logitech Cordless Mouse
My Logitech mouse is wireless # CE0682 and the red light on the mouse is always flashing, even when on the receiver. I also have some problems when I want to use the mouse to hilight a block of text, as I...
Gina, I've had my Logitech ce 0682 for years and have had some similar problems. The mouse is supposed to rest in the cradle and recharge the batteries, but I've noticed that it rarely works for me. The connectors on the mouse seem to scuff and corrode easily and I'm sure that degrades its ability to charge batteries. So my solution was to buy a 4 pack of rayovac rechargable batteries(AA) and a usb battery charger. I never put my mouse in the cradle now and keep 2 batteries recharging at all times so I always have fresh batteries when that pesky red light comes up telling me the batteries are dying. As far as your highlighting text problem. Sorry don't have a solution on that one.
Sep 03, 2010 | Logitech Cordless Mouse
Docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
May 27, 2010 | Logitech MX1000 Laser Cordless...
Green light on charging cradle is blinking green and mouse does not work
charger cradle lights are both on- when I pur mouse in charger lights on mouse do not come on.
Aug 12, 2009 | Keyboards & Mice
Stopped recharging
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Aug 05, 2008 | Logitech MX 700 Mouse
Mouse stoped charging lights on charger stay green but mouse light stays red and wont work most of the time i put regular in and it works but wont charge help please
this is a problem with my mx700. you need to constantly clean the two brass coloured connectors at the bottom of the mouse. an eraser works well. even with this you sometimes need to jiggle the mouse a little in the holder to get it to charge. this is not logitech usual standard and very annoying.
hope this helps.
Mar 01, 2008 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Flashing light
Jul 25, 2007 | Logitech MX 700 Mouse
Logitech LX700 - Cordless Keyboard and Rechargeable Optical Mouse (LOGLX700) Logo
14 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
