Question about Projection Televisions
Mitsubishi projection tv VS-5055
Picture went out no picture at all nothing on screen
bought new in 1995
  • 1153 Answers
SOURCE: mitsubishi model vs-5043
Posted on Aug 26, 2007
  • 1694 Answers
SOURCE: Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Posted on Oct 23, 2007
SOURCE: Mitsubishi model # vs-5055 will power off after a minute or so
We have a 1994 Mitsubishi 52 or 54 inch, Model # VS 5055. The remote is broken and the parent control is on so we can not use the regular buttons and we cannot shut off the parental controls. Any thoughts?
Posted on Jan 04, 2008
  • 31 Answers
SOURCE: mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Posted on Jun 30, 2008
  • 1187 Answers
SOURCE: Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Posted on Jul 12, 2009
SOURCE: I have sound, but no picture on my Mitsubishi
Posted on Oct 02, 2009
0 characters
1 Points
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
I have a Mitsubishi TV model VS 5055 1994. The
you need to replace convergence IC chips to resolve this issue .
Nov 28, 2010 | Mitsubishi Projection Televisions
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Lost the remote to my mitsubishi big screen tv
Just bought a new remote for my VS60603, then main board goes bad upon moving to new location. Never used it. Interested in purchasing it? Email
Apr 21, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Nothing happings
jen, Please verify Model # and mo / yr off the label on the back of your new set.................................T.
Nov 23, 2007 | Mitsubishi WS-55513 55" Rear Projection...
VS 5055 has distoration, discoloration, screen not complete.
Do self diagnosis test by pressing input and menu on set at the same time for 5 sec. It should blink a 2 digit code. Remember code and let me know.
Nov 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Most older TV's require hand-soldering at least once in their lives,esp. regulator pins in power supply circuits.That work
requires the chassis to be pulled = major labor.......T.
Nov 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Projection Televisions Logo
417 people viewed this question
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
