Question about XM Radio (XMP6000)
Im using a cassette adaptor for my xm radio,i now just get static and ive tried 3 difrnt adptrs,same result and demagnitize didnt help, any ideas?
  • blueextc3221
    blueextc3221 May 11, 2010
    Use an FM modulator. It broadcasts the signal for approximately 6 feet, and can be picked up by your Car Stereo set to a particular station.
3 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: Need an In Dash XM Radio Installed on 1997 Honda Prelude
well...there is an after market for this, but it's a little high end at this point.
Posted on Jun 18, 2008
yammy_alf
  • 666 Answers
SOURCE: My xm radio has a lot of static no matter what
check from your so rounding if have electric motor running. that machine also give static response to your radio unit.
Posted on Apr 05, 2010
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
How do i remove a stuck cassette tape from a 1994 chevy truck player?
Does it make noise or move when you hit the eject button? If so, slide a butter knife under the exposed edge of the tape drive adaptor about an 1/8" and hit the eject button. Just a little upward pressure should help it release. It the eject button has no effect, you may need to pull the radio out, open the cover and manually turn the eject drive assembly.
Sep 05, 2014 | 1994 Chevrolet Silverado 2500
Will delphi sa10000 without cassette player
Should be able to hear Sirius channels through your FM radio. Cassette is better, but you can just set up your FM radio to the same channel as you set the Delphi unit. See instruction manual (download from online here) http://www.siriusretail.com/pdf/hardware_support/delphi/skyfi_operations.pdf
Jun 01, 2014 | Delphi SKYFi SA10000 XM Radio Receiver
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
My delphi roady plays through cassette adaptor. Volume is very low even when audio level is moved all the way up. ???
You need to cycle back through after puttung the cassette in. Mine did that (before the cassette feature stopped working altogether) and I would press my "source" button so it would go from the cassette to the radio, then CD and back to the cassette - the sound would be back to normal again.
Oct 06, 2009 | Delphi Roady XT XM Radio Receiver
Cassette players jammed
actually you can not lubicate the cassette players. it has to do with a belt inside. your players may need to be demagnitized. i would go to radio shack or electronic store and try a cassette cleaner/demagnitizer and see if that solves the problem. i would even try different batteries or a ac power adapter if you have the plug. some batteries make units run slow. i would even get a can of dust cleaner that you find in the electronics section. you spray it in and it cleans the inside of the dust that may be inside.
Mar 22, 2009 | Sony Audio Players & Recorders
I have XM radio hooked to cassette player adapter in my car. The new adapter keeps sounding like it is rewinding. XM plays for 30 seconds and then ''rewinds'' again, over and over.
Unfortunately your tape play has the auto reverse feature. It is detecting that the tape is not turning via a reel counter. Sensing no movement ( as you have an audio adaptor inserted rather than a real tape) it is trying to switch to the other side of the tape.
Not very much you can do.
You could purchase an FM modulator and basically re-transmit the Xm over an un-used frequency on the FM band to slve your problem
Mar 12, 2009 | RCA Audio Players & Recorders
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
FINDING A RADIO FOR A SEMI TRUCK
Those measurements are a standard single DIN automotive radio.
You need to find a "XM ready" or "With XM controls" radio and install a separate XM receiver box. For example this would be the in dash deck:  http://www.crutchfield.com/App/Product/Item/Main.aspx?o=p&showAll=N&g=300&i=158XRCA350&tp=5684 And this is the XM receiver: http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=3951
I would suggest finding an in dash receiver that also does HD radio as well as XM.
May 16, 2008 | Car Audio & Video
Noise with casette adaptor
Well Jill the problem you are having is called inducted noise. The lighter power adapter cord is inducting electrical current to the cord used by the cassette adapter thus creating the the noise you've been hearing. Do your best to separate the two cables as much as possible. I realize that your unit may have both cords coming out of th same side, and that's fine. the longer the run of wire, the easier it is to have induction issues. If the cords do come out on the same side, run one up and the other down away from the other cord. Do not coil the lighter adapter or cord either, it increases the chance of being able to induct noise. If your unit is to close to the lighter assembly you may need to move the unit to another location in the vehicle itself to help combat the noise issue. Other options include to shield the cassette adapter wire, i use aluminum tape for heating/ac ducts. The only other option i can see is purchasing a FM modulator which will transmit the units sound wireless-ly through an FM radio channel. You will want to check and see...i do believe most XM radios have a FM modulator built in. Hope this helps, and good luck.
Oct 03, 2006 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
