Question about Microwave Ovens
My turntable quit turning, I looked in and found a what appears to be a piece of what looks like glass that acts as a shaft between the motor and the turntable was broken. I cant find the part or any mention of this part anywhere?
  • 5,911 Answers
If you are talking about the little piece that the center of the tray sits on (not the carousel ring), its called the coupler. Its actually made of plastic on all the microwave ovens I've ever worked on. I've never seen one made of glass. It connects to the turn table motor shaft. If you post back with a complete model number, I may be able to assist you in locating a part number.
If the coupler is not physically broken, you may be identifying the wrong part as your problem. The turntable is driven by a small motor which is mounted under the bottom panel of the oven. The coupler is mounted to the shaft of the motor and the glass tray sits on the coupler.
Post back and let me know if you need a coupler, or if your motor isn't turning. You can tell by removing the glass tray and pulling straight up on the coupler. It should come off the motor shaft in one piece. If its not broken, your motor probably needs replaced.
Posted on Sep 09, 2009
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
The piece holding the glass turntable does not turn appears to be burned on the insert peg and smells of burnt machine oil
Hi
Sounds like its either the shaft is gummed up with spillovers or the motor has seized because of either spillovers or lack of lubrication ( they usually go for years tho)
If mechanically minded you will need to remove the glass cooking plate, REMOVE THE POWER CORD, turn the whole thing upside down to see if you can access the motor by removing a metal plate etc - if so see if the shaft can be turned by gripping carefully (so not to damage) with pliers or similar. If it moves apply a drop of oil to the area where the shaft enters the motor - chances are the bearing area there is dry of lubrication. Clean off any food debris also and leave wiring alone.
If it now moves freely, reassemble, replace bottom cover plate and turn right side up, plug in and try.
Otherwise if not mechanically minded or still no go you will need to have it serviced
Jun 09, 2010 | Microwave Ovens
The plate is not turning
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need.
If the model number is correct, the part number for a replacement motor is WB26X10038. You may also check the turntable shaft to make sure it is not stripped and slipping on the motor shaft. The part number for the turntable shaft is WB06X10138.
If you have any questions, please post back and let me know. I hope this helps you.
May 12, 2010 | GE JVM1660 Microwave Oven
Turntable does not turn and the wheel underneath makes grinding sound
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
repairclinic.com
If the model number is correct, the part number for a replacement motor is WB26X10135. You may also check the turntable shaft to make sure it is not stripped and slipping on the motor shaft. The part number for the turntable shaft is WB06X10564.
May 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When the glass tray turns it makes a noise. When
This problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to (and is located under) the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray that you were referring to. The following link explains how to access and replace one:
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
Turntable will not turn with glass turntable on it
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Turntable no longer turns
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Nov 25, 2007 | Microwave Ovens
Spacemaker 1800 Turntable
If the noise goes away when you turn the turntable off, it sounds like you have a turntable drive motor that is going bad. They are fairly easy to replace and not terribly expensive. You can access the motor by leaving the oven in place and UNPLUGGED. Remove the bottom panel. You will need to remove the turntable coupler (the plastic piece that spins the glass carousel) and remove a few screws in order for the motor to come out through the bottom of the oven. There should also be a quick connect plug that plugs into the motor. The motor runs about $35 and the turntable coupler (if you wish to replace it as well), runs about $8. The part numbers are 769741 and 769278, respectively at repairclinic.com. I hope this helps you.
Jul 07, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
