Question about Car Audio & Video
My dvd receiver works great when im parked but as soon as i put the parking brake down the screen pops up a caution sign but i still here the sound
  • 733 Answers
Check your wiring. chek the harness. the only wires that should be plugged in are the rca's, red(ign. power), yellow(constant power), blue(remote to amp if available), and of course black(ground). make sure you don't have wires that don't need to be plugged in to the harness as they might be used for other purposes.
Posted on Sep 09, 2009
1996, stuck in park shifter moves fine, but car will not roll in neutral, but if i rock car back and forth it will pop out of park and then i can drive forward and backwards just fine. as soon as i put it...
The park pawl is spring loaded and it sounds like that spring has broken. The problem is, the trany has to be removed from the car and completely disassembled to fix it. The linkage for park is all mechanical, the transmission could be completely out of fluid and park should still work. I guess, I would get into the habbit of setting the park brake, then put the car in park and pull it out of park, before you release the park brake. You could also leave the shifter in the neutral position and set the park brake. This will allow you to start the car but you won't be able to remove the key. Hopefully the brake cables are not all rusted up. Good luck.
Feb 25, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
I have a pioneer AVH-P4000dvd 2 din in dash dvd player. I hooked it up right, I did not do the by-pass, I hooked it up to the e-brake. When I play a dvd I get audio but no video. I have full control of the...
push in the driving brake. while holding in the brake , engage the parking brake. disengage the parking brake.then repeat this step again. a notice should pop up and you should be fine after that. I put one in a F-350 and had the same problem.
Jun 27, 2009 | Pioneer AVH-P4000DVD Monitor
I have a ripseed dv 720 dose any bothy no how to get ride of the caution screen when i try to insert a dvd
take the pink lead....should be labled as parking. professionally this should be wired to your hand brake/ parking sensor on the ground, but to avoid the 'must have parking brake applied' bit, put it straight to an earth to override it.
Jun 06, 2009 | Pyle (PLVW1045R) 10.4 in. Car Monitor
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Video wont play
Go to www.google.com then type JENSEN CODE choose the first one on the top.
Mar 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Can't view dvd
just hook the parking brake wire to the ground wire on the radio.
Mar 17, 2009 | XO Vision XO9013 Car DVD Player
Car cassete player and Radio (AM/FM) doesn't work when I drive
It sounds like you are having issues with one of your wires being connected to the Parking Brake. I know certain DVD players and back-up camera devices have a wire that when connected to the parking brake, will turn the screen blank until you are parked again. I am not sure if this is the issue though.
Nov 28, 2008 | Car Audio & Video
Vm9312 in dash will not play video
Go to your radio tuner screen and go to your set up page then use your remote and press 5,4,3,2,1,0 and hidden menu will pop up then you will have to press the tool looking button on the left side of the screen and it will give you an option to it off so you dont have to hook up the pink wire.
Nov 17, 2008 | Jensen's VM9312 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
