Question about Electrolux Coffee Makers & Espresso Machines
Espresso machine rubber ring tear causes water leak
I have a Electrolux ees200 espresso machine of which the clear soft rubber ring (slightly over 2in/6cm in diameter) is tearing. This ring separates the high pressure water dispenser and the metal sieve plate through which the hot water is pressed into the metal coffee filter (removable). The tear is not all the way through, but under the pressure the machine sometimes 'pops' and water explodes through the tear outwards spraying the machine and everything around it. I tried wrapping some tape around it but it melts/cracks under the heat.
Hi may i know whether Electrolux Pump Espresso Model EES200 can make single shot of espresso? Cos I tried but the machine only make 1 cup of coffee. Please help. Thank you
Posted on Apr 20, 2012
SOURCE: Krups XP 2070
I have the same problem and this is the second machine. I warrantied the first one because it stopped working. I brewed one espresso with this machine and now no water or steam will come out. Help?
Posted on Jan 13, 2008
JSEhandyman
  • 368 Answers
SOURCE: Salton MEEX20B Espresso Machine with broken coffee carafe
Here is information about the Salton, Inc. customer servicesite for replacement parts or manuals. If they don't have them, they should knowwhere to send you (though if they don't, I'd seriously wonder about thecompany).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 01, 2009
  • 10 Answers
SOURCE: francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
  • 54 Answers
SOURCE: Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Posted on Jul 11, 2009
  • 39 Answers
SOURCE: The espresso side of the
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
Posted on Dec 31, 2009
What causes water to leak from underneath the unit?
Most often the problem is that the rubber rings are too old. The best is to open the machine, put the lid back on top, add the water container, add water. Push the espresso button, and afterwards (when the espresso is finished) open quickly the lid and check the origin of the water. I have a magic de luxe and it turned out that when i replaced the boiler, one of the high pressure tubes were damaged. Other frequently occuring problems are related to old rubber rings. the cost virtually nothing, and are easy to replace!
Cheers,
Andre
Apr 01, 2011 | Saeco Magic De Luxe Espresso Machine
Does not pump and leaks water
It has problem on pump motor that's why it doesn't pump. Also water leaks is cause by a o-rings becoming thinner rubber and or boiler has cracked.
This answered your question.
Mar 30, 2011 | Keurig Platinum B70 Coffee Maker
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Water leaks around groop
There is a gasket "o" ring around the group where the filter sits. This it might be dirty or tear out. Try to clean with brush and if you still have leak then replace it. Visit Partsguru.com for the brush and other parts
Nov 08, 2010 | Gaggia Classic Espresso Machine
Leaking pump head at adjustment for pressure - worn rubber seal or snapped pin. Where to get a new pin?!
Unless you have an old pump you can take the pin from you will have to get a new pump, as for the o-ring since there is no hot water there a small o-ring can be found at the hardware shop or a home espresso machine dealer/repair agent.
Sep 19, 2010 | La Marzocco Linea Group 1 Espresso Machine
Water leak causes the main power to trip. can you
Yes it can be repaired, I would suggest getting a rebuild O-ring kit for your machine, it comes with all the gaskets and O-rings that you will need for the machine.
May 30, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Water keeps leaking out onto countertop, even when off. Doesn't matter if reservoir is at max or min.
I had the same problem.. I took the clear rubber grommet piece off and added an additonal o ring I had left over from a pur water filter kit and it stops the water from leaking. What does annoy me is that it only pushes water cleanly through for about 30 sec then it drips very slowly for the remaining brew to fill two full shots (I like mine big).
Jan 17, 2010 | Hamilton Beach 40714 Espresso Machine
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
JURA X90 ESPRESSO MACHINE LEAKS UNTO COUNTER
inside the machine a rubber tube is broke or loose causing this leak!
Dec 09, 2008 | Jura Capresso Impressa X90 Espresso...
Water in dump box. Saeco Vienna Deluxe.
Had the same problem. I found that the rubber O ring around the plunger was split and leaking water into the dump box. It could also be that your O ring, if not split, is too worn to continue sealing. Try replacing the O ring. I am in process of doing that myself as I just found the problem.
Another possibility is that the filter that filters just before expelling the coffee is clogged and the coffee cannot escape, if that is the case you probably would be getting coffee and not clear water, I would opine.
Feb 17, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
445 people viewed this question
Top Electrolux Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Electrolux Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
