Question about Sharp UX 510 Plain Paper Thermal transfer Fax
Still black lines
I have the same black line problem, cleaned the glass 3 or 4 times, did not help Can it be a problem under the glass/if so can it be cleaned?
  • wink06 Sep 11, 2009
    They all work
    President:
  • 3,085 Answers
It is possible one of the LED elements in the scanner block is not working.
Posted on Sep 09, 2009
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
Black Parallel lines across center of paper from edge to edge on Sharp MX-2300N. Lines are about 3/8'' wide and fill about 5 inches in the center of page from left to right.
I am assuming you made sure the scan glasses are clean (the big main one and the small thin **** glass on the fleft side of the main glass.) make sure the mirrors under the main glass are clean.
This is usually caused by the drum starting to go bad and or the main charge unit for the black drum. Knowing the drum counter would help or the age of the drum. open the front cover and remove the big black waste toner bottle. Behind that you will see 4 protruding knobs - slowly pull out each one till it stops and push it back in till it stops. do this several times for each color and black. Clipped onto the door there should be a long thin plastic wand with a felt sponge on the end. If you look under each drum/developer unit you will see a small ****/hole with a sticker of an arrow on it..push the wand into this **** (felt side first - facing down) all the way till it stops and pull it all the way out. do this with each color - this cleans the laser glass. These two methods get rid of most lines. If the lines persist you will need to replace the main charge unit on the black drum.
Jan 16, 2010 | Sharp Office Equipment & Supplies
Black copies canon laser class 510 only when using the adf. copies fine from the glass.
Are the copies solid black or black lines ? If there are black lines, try cleaning the **** glass under the ADF ( above the large glass ).
Oct 09, 2009 | Canon LaserCLASS 510 Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Dec 04, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Sharp UX 510 Plain Paper Thermal transfer Fax Logo
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
