Question about Air Tools & Compressors
How do i repair a broken air regulator on a husky portable air
Broken air regulator on a husky portable air compressor model H1820F
Just to add to the posted advice which would have prevented the repair I'm having to make and the things I'm learning the hard way as I'm fixing the stripped regulator on my H1826F from 2008...
here's the damage:
how do i repair a broken air regulator on a husky  - 8_17_2012_2_31_40_pm.jpg
Other thing that was tricky is getting the cover off the top to get at the guts - most of the holes held screws - easy to get off, but the bottom holes were tricky as the bolts are so far in it's hard to tell what you are dealing with... here's what I found after I broke things (gotta love superglue - it's all better now):
8_17_2012_2_33how do i repair a broken air regulator on a husky  - 8_17_2012_2_34_29_pm.jpg /><br><img src=
once you get the bolts turning, loosen them till the cover will pull apart and you'll get them both off in one piece, threads intact.
Posted on Aug 17, 2012
On the H1820F, the regulator locking nut sets too far behind the cover to reach.how do i repair a broken air regulator on a husky  - _824.jpgAfter setting the pressure, if you do not lock the knob normal vibraion will cause the threads to chatter and strip out and then you will have to replace the regulator.
Best to remove the cover so you can reach this locking nut.
Posted on Feb 26, 2011
    Novelist:
  • 141 Answers
You will have to repalce the air regulator. Campbell Hausfeld is the maker of the Husky air compressors. There should be a different model number on your compressor that you can use to locate the part number on the chpower.com website. The only problem that I have come into is that the parts are not available for these models on a long term basis, and they may not offer any repair parts at all. If you can not locate the part on the Campbell Hausfeld site call Home Depot and ask them where you can get the part.
Posted on Sep 09, 2009
    New Friend:
Http://www.ebay.com/itm/AB-9415883-Bostitch-Regulator-Manifold-Pressure-Reducer-CAP2000P-OF-Type-0-/260815509190?pt=LH_DefaultDomain_0&hash=item3cb9d0d6c6
Posted on Jun 25, 2014
  • 1 more comment
  • Lawrence Zu
    Lawrence Zu Jun 25, 2014
    http://bostitch.com/servicecenters.asp
  • Lawrence Zu
    Http://www.ebay.com/itm/AB-9415883-Bosti...
  • Alex Tang
    Alex Tang Oct 21, 2015
    I don't actually think this is the right regulator for the Husky compressor. The gauge is on the wrong side (take a look at the pic for the more "official" part here:http://www.mastertoolrepair.com/air-regu... The Stanley Bostitch part is a mirror image.
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Need manual for husky air compressor H1820F
Ask here, they may be able to help http://www.about-air-compressors.com/husky-air-compressors.html
Sep 16, 2012 | Husky Air Tools & Compressors
How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Dec 31, 2010 | Electric Air Tools & Compressors
Air Tools & Compressors Logo
7,850 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
