Question about Apple iMac G4 Desktop
I want to replace a shot hard drive on a 20 inch imac. I have a 250GB Serial ATA hard drive. Anyone know the steps?
  • 558 Answers
Well there a couple of torq or philips head screws on the botom you will have to turn they do not come out just a simple turn to diengage them,you will have to place the monitor area between your legs and rest the base on your legs as the base is heavier than the top.Once you have pulled these screws there is one cables that you will have to unplug and a ground wire you will have to remove from the chasis(one screw).This will allow you to completly remove the base.Now that you are in there carefully long at the wire orientation and the location of the hard drive.Remember as you replace the drive how the cables are placed as when you replace the botom cover you do not want to pinch any cables.
Good luck
Posted on Sep 09, 2009
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
Hard disc test failed, boot device not found, couldn'f find 2 HDD'S on system. These are my error codes
Most definitely. If the drive failed a S.M.A.R.T. test or DFT (drive fitness test) then replace the drive and re-install your OS, drivers etc.
Jan 26, 2013 | Toshiba HDD2J95 250GB 5400 rpm 8MB Buffer...
Replace hard drive
http://www.ifixit.com/Guide/Installing+iMac+Intel+24-Inch+EMC+2111+Hard+Drive+Replacement/5211/1 This guide is for your model.
Oct 11, 2012 | Apple iMac 24"/2.33Ghz Intel Core 2...
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device now displays a red light, next to the standard green light. I tried...
The disk-drive inside the enclosure has "failed".
Open the enclosure, remove the disk-drive, and take it to any computer-store, to buy a compatible replacement. Install the replacement disk-drive.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My device manager says this hard drive is working fine but when I try to expand or open the drive I get a message saying "the disk in drive e is not formatted" This is added 3.5 inch Maxtor 250GB with an...
The message about it not being formatted means that at least some part of the drive is corrupt or the cable is faulty.
First thing to try would be to connect the drive on a different cable, see if it helps. If that doesn't solve the problem you're most likely looking at a faulty drive. Maxtor drives are quite well known for their low reliability.
Apr 04, 2010 | Maxtor (6L250R0) 250 GB Hard Drive
Which Portable hard drive can be used with both a Windows PC and an Apple iMac please
Hello
Well, you can basically buy any external drive and it will work on both operating systems if you format it to a FAT32 format.
If you buy a new drive, you first need to delete the partition on the new drive using Fat32 formatter, and then format it in Fat32 file system.
Here is a link to where you can download the software for free, and get instructions on how to do this.
http://tokiwa.qee.jp/EN/Fat32Formatter/
Hope this can help.
Kind regards
Andrea
Nov 16, 2009 | Seagate 250GB 7200RPM ATA DVR Drive:...
Apple iMac G4 Desktop Logo
153 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
