Question about Kenmore Dryers
Dryer is not puttign out any heat.
Dryer is not putting out any heat.
  • Controlfrk
    Controlfrk May 11, 2010
    Model Number is needed...inside door. Electric or Gas?
  • 304 Answers
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
On some newer models Replacing the heater, if necessary, can be done by disconnecting the wires at the lower left of the heater can on right. There will be a screw on each side edge of the lower half of the can. Remove the two screws and pull off the back lower half of the heater can and reverse the above process to install the new heater.
On older models heater replacement may require lifting of top. Under the lint filter cover there are two screws. Remove them WITHOUT dropping them into the vent or you may cause a more serious problem. Insert a putty knife between the front and top about 2 inches in on both sides. This will release the top for raising.
Posted on Sep 09, 2009
Why isn't my dryer putting out any heat?
Is it a gas dryer? Are you out of gas?
If it's electric, the heating element may have just burned up. They do that.
Jul 26, 2014 | Frigidaire Dryers
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Will not put out any heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 20, 2010 | Estate TEDX640JQ Electric Dryer
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heat elament is out
  1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Unscrew the screws holding the element in place and pull it out.
  5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Sep 23, 2009 | Washing Machines
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
