Question about Kwikset Locks & Locksmithing
Key won't turn deadbolt
I recently purchashed a Kwitset Smartkey deadbolt and handle (all in one package) from Home Depot in June 2009. After installing it we had no problems until yesterday. Now the deadbolt doesn't work with the key. It turns fine from the inside. Any idea as to what's going on and how to fix it? At first one of the original keys worked intermittently, but now none of the original or copies work at all. Inside knob turns fine, no problems
    Scholar:
  • 49 Answers
Try using your smartkey to "rekey" the lock to the original key... there's really no reason to buy the smartkey system unless you change locks alot... they are meant for the apartment industry more than anything I believe... in any case, the smartkey system allows you to rekey the lock without removing it from the door... so, use the original key and use the smartkey to rekey it or select a different cut and key it to that key... should solve your problem.
Last resort... take it back to HD for replacement.
Posted on Sep 09, 2009
Testimonial: "Thanks, that's exactly what I did (before I read your response). I ended up buying another brand too. I'm disappointed in the quality of Kwikset."
I bought a DEFIANT KEY PAD DEADBOLT.
Usually you just take it apart and turn everything around, the keypad would be turned over and the bolt would be removed and turned to the reverse of where it was.
If it is the type below, I am thinking you would remove the deadbolt part and turn it and then there must be something inside that reverses the throw of the bolt. No instructions with it?
Defiant Electronic keypad Deadbolt Satin Nickel The Home Depot Canada
Nov 11, 2015 | Defiant Stainless Steel Ball Entry Knob...
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
IQ America Wired Doorbell 8-note westminster Model DW-2840 needs a diode
For the IQ America doorbell (mine is a DW2860), the diode that was packaged was a 1N4004. Search for it on eBay. They are very cheap.
Aug 28, 2012 | Cars & Trucks
Just bought a John Deere d140 had it delivered by home depot. Went to turn key, tractor completely dead. Lights won't even turn on. Looked in manual says to charge battery. What do I use to charge this...
are you pressing down the clutch/brake pedal? is the pto switch turned on?are you sitting on the seat?the lights only come on while its running not with the key turned on
Apr 30, 2012 | John Deere Garden
I am trying to replace brass Schlage deadbolt locks with black. I need to adjust the deadbolt from 2 3/8 to 2 3/4 before I install the deadbolt. I can not get the deadbolt to turn in the groove.
Home Depot has a template and tool that will make the hole bigger, it comes with everything you need except a drill. I think its around $20. It clamps on to the door and has the holes alighned to be drilled. Good luck. remember, it is important to get the holes centered!
May 15, 2011 | Garden
Schlage Combination deadbolt purchased at Home Depot about a year ago. Has key option too, but it isn't used.
Okay, so what's the problem that you're having with the lock. Please try to furnish the model number/ brand of the lockset.
Apr 26, 2011 | Locks & Locksmithing
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Key will not turn on deadbolt
The pins are probably frozen. Spray some w/d in lock, then try with key, keep repeating till key turns, this should free up lock. Dirt and moisture gets in lock cyl and gets gummed up. You could also remove handle and have locksmith take apart and clean, they will then use graphite instead of w/d wich attracts dirt.
Jul 20, 2009 | Locks & Locksmithing
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
2,474 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
