Question about Whirlpool Dishwashers
Dishes coming out dirty
I HAVE A WHIRLPOOL GU2300 DISHWASHER WHICH HAS BEEN A GREAT UNIT UNTIL RECENTLY, THE DISHES ARE COMING OUT DIRTY, THE RACKS FILTERS AND SPRAY ARMS ALL APPEAR TO BE IN GOOD REPAIR WHAT SHOULD I LOOK AT NEXT?
Thanks
D.
  • 86 Answers
Go to wal-mart and get some dishwasher cleaner works great!!
Posted on Sep 09, 2009
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
The dishwasher is old 1993. Given great performance until recently. Dishes and pots are sometimes coming out a little dirty and have to run them through another cycle. Is it ready to be thrown out or is...
Try some maintenance cleaning on machine first.check water temp going in machine . let unit run on a hot cycle with some vinegar only.Add correct soapand rinse aid which is very very important.
Feb 24, 2010 | Dishwashers
Upper dishes are coming out dirty. want to check
dont no where filter is but vinager on empty load works maybe couple of times
Jan 31, 2010 | GE GLD5600NCC / GLD5600NBB / GLD5600NWW...
I have a kenmore elite ultra wash he (model 665.1315) dishwasher - one year old. No problems until recently. It just started leaving a substantial film on the dishes, cutlery and racks in the past 10...
there is calcium in water and it builds up around the pump and the flow you typically have to take it all apart to clean it or there is crud in your drain inside the dishwasher, basically you are swishing around the dirty old water and food particles, Ralph this is from not rinsing dishes first and using special dishwasher soaps to prevent the build up thus clogging pump and exit lines. pull the pump apart if you dont find clogged filters.
Nov 24, 2017 | Kenmore Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwasher
Make sure not to prewash your dishes before you put them in the machine. The water needs to be dirty to activate the enzymes in the detergent. Are the dishes coming out cloudy? Also a sign of prewashing your dishes. Use only powder detergent and clean your machine by running 2 cups of vinegar on hottest cycle once a month. No gel and no tabs. They cause a build up in the unit and causes poor performance. Use rinse aid. Hope this helps.
Mar 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwashers Logo
170 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
