Question about Whirlpool LER5636P Electric Dryer
The dryer doesn't start when turned on. Has been working fine for 4 yrs from new. It ran yesterday but didn't dry - and wont start today. The electrics still "work" - they "tick over" when turned on...but no dryer rotation kicks in. Are there any fuses which commonly need replacing ? Any help greatly appreciated !! Craig.
  • 304 Answers
The problem you describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
Posted on Sep 09, 2009
When I stop pushing the Start button on my NEW dryer it shuts off.
please check out the motor, or motor switch
Jan 20, 2015 | Dryers
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I have a front loader fridgidaire dryer its a couple yrs old today when i put clothes in it to dry i usually hit the start button and then hit the start button again to start it but today I did it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Frigidaire Electric Dryer
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
I RAN MY DRYER ALL DAY YESTERDAY AND IT WORKED FINE, WENT TO RUN IT AGAIN TODAY AND IT RAN FOR A SECOND AND SHUT OFF AND WONT COME BACK ON.
You likely have a blown belt. Reach into the drum and rotate by hand if it spins freely the belt has broken, triggerring an auto shut off switch. You can change the belt yourself if you are mechanically inclined. Post back with more info
Sep 20, 2009 | GE Dryers
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Dryer won't shut off after cycle
i got to know what cycle you are using the timed dry or the auto cycle timed dry you may have a bad timer if auto dry it coult be the auto dry resistor or it could be a clogged vent.
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
153 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
