Question about Microsoft Zune JS8-00001 Digital Media Player
Zune won't turn on
My zune just turned off during class and will not turn back on, unless its connected to my pc but as soon as unplug it it turns back off
  • 313 Answers
Try to keep it plugged in for 12-24 hours to give it a full charge and see how it does....
Posted on Sep 09, 2009
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
My ematic mp3 player will not turn on and it is fully charged. I had realized i overcharged it and it wouldn't turn on so i just clicked on reset and now it won't turn on, even when i plug it into the...
You shouldn"t be able to over charge it.unless there is something wrong with the unit.i had a simular problem with my Zune.it was fully charged but as soon as i unplug it it would not power on,it would only work when plugged in,i had it replaced under warrenty.call your manufacturer.
May 07, 2010 | Beond Ematic EM304CAMB Digital Media...
8 GB zune, unplugged it while it was charging and it wont turn on
Try to restart the Zune using this procedure:
http://support.microsoft.com/kb/946064?sd=zune
If this does not work then you can try resetting it to Factory Defaults:
http://support.microsoft.com/kb/927001/en-us
Only do this if absolutely necessary, all content will be erased from the Zune. Not a huge deal if you have it all on your PC with the Zune software but still a last resort.
If neither of these work then you have a hardware problem.
Jul 25, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I cant seem to turn off my zune completely, only pauses the unit, the screen goes black after holding the pause button, it appears to be off, then i go to use it hours later and the battery life has...
The Zune never really turns off completely. To turn it off, hold the back button and up on the Zune pad. As soon as the screen turns black, let it go, and turn on Hold.
This will turn it off completely.
Mar 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune Froze
all of the zunes 30gb in the world went dead last night go to zune support.com and request a repair they will be helping you soon .
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
ZUNE 80G BATT
Hello LB613,
It sounds like the battery is failing. Over time the amount of operating time you can expect between charges will decrease. The battery will still come up to normal voltage and thus will appear to charge normally but it will become depeleted very quickly during use.
You can contact Microsoft to get more information about a battery replacement for your MP3 player. The official Zune website is: http://www.zune.net.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune Froze, erased content, and wont sync with PC.
Yes. There are several solutions to this. Rather than retype them, you may want to check out the forums at www.zune.net or support.microsoft.com.
Most likely you'll have to remove the Zune software from the PC, re-install it, reset the Zune.... I think you get the picture.
May 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
PC will not detect my zune.
Hey!! I just fixed mine! I had recently installed drivers for a PS3 controller, and for some reason those were conflicting with the Zune.
To fix it, I went to add/remove programs, and then removed the libusb program, that fixed it instantly! Good luck!
Dec 04, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune wont turn on
I turned on my Zune and the screen froze so I turned it off but it would not turn back on.
I went online and read somewhere that if the screen freezes then you should press up and back and wait for the zune insignia to come on. Well my zune was not just frozen it would not go on but I tried the up and back thing and it worked. it took about 9-13 seconds but it worked so give it a chance and if that doesn't work try charging it overnight. Hope that helps :D
Nov 12, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
125 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
