Question about IOGear GPSU21 Print Server
The software supplied on the disc doesn't run on Vista 64
I've tried accessing the iogear site but keep on getting bounced - something funny there too
    President:
  • 2,923 Answers
Would you like to download the utility for the IOGEAR GPSU21 Print server?
You may check the link below to download the software/driver utility:
http://www.iogear.com/support/dm/driver/GPSU21#display
Thank you and good luck!
Posted on May 11, 2010
  • 30 Answers
Here is a direct link to the software download page.
Posted on Sep 25, 2009
Installing logitech c160m webcam. My operating system is vista. Whether or not I download the software from disk provided or download from logitech web site the file won't install. I've tried...
Hi Welcome to FixYa!
1)Are you the only one who is using the computer? If not, be sure that you are or you have Administrator rights to install anything on the computer. Because if your account is only a standard user type, you dont have privileges of installing any software or device on the computer.
2)If you are the Administrator of the computer, try to right click on the installation file and select Run as Administrator and see if this will work
3)Check also your security softwares installed on the computer. (e.g Antivirus Softwares) If you have them installed, try to disable them first and run the installation file for your webcam
4)If it still doesnt work, do a clean boot on the computer. You could do this by going to the System Configuration Utility. (type msconfig on the searchbox to access this utility) -you should be seeing something like this: mondimondz_2.gif -once you have a window like this, go to the startup tab>click on disable all>click on apply, then go to the Services tab>put a check on the Hide all Microsoft Srvices option>then click on disable all>then click OK -it will now prompt you to restart the computer -once you get back to Windows, try now to reinstall the software for your webcam
5)if all else fails, your last option is reinstalling Vista on your computer.
Hope this would be a big help!
Jun 17, 2011 | Computers & Internet
Hi. I ve been trying to install the Umax Powerlook III Flatbed Scanner on my 64bit computer which is running Windows 7. On starting the machine getting an error that Bios not installed. Please help me as I...
get to the bios settings by pressing the F2 on start or del if it is a desktop ...(f12 for Hp pc ) and there set the optimal factory defaults ..(it will be a line that instructs how (F9 or F7 I think ) after that just save changes with F10 and see if the error keeps showing on ...if does it must be a issue with the driver or a thing like that ..so o to the Umax support site and get the drivers and software for windows & on 64 ..if it is available (if not get for vista on 64 ) and install again from scratch ..
Jun 16, 2010 | Umax PowerLook III Flatbed Scanner
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
May 24, 2010 | IOGear GPSU21 Print Server
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
ArcSoft TotalMedia Theatre 3 issue
Download from Arcsoft the "BD Assistant"and it will tell you where your system is failing the HDCP check.
I had an issue with the LogMeIn mirror driver showing up as my graphics card. When I uninstalled it, my HDCP status was good again. The funny thing is LogMeIn and TMT3 run fine together but only under certain circumstances changing multiple monitors do you get this conflict.
Dec 28, 2009 | Arcsoft TotalMedia Extreme - Windows for...
Getting IOGEAR GPSU01 to work on Vista 64
If you know the IP address of the print server you can create a TCP/Ip print port. IOGear offers direction on how to create this type of port and here is a link.
http://www.iogear.com/support/faq/id/297
Jul 29, 2009 | IOGear GPSU21 Print Server
Iogear SAYS the driver works for 64 bit but i keep getting an err
The drivers for a 64 bit version of Vista will almost never be the same as the 32 bit version.
IOGEARs website does not list a 64 bit driver for your device.
Jan 19, 2009 | IOGear (GBU211) Bluetooth Wireless Adapter
IOGEAR GBP301 and HP Deskjet D1341
Please make sure that the printer is already VISTA compatible meaning if it is known to have VISTA printer drivers.
Jan 17, 2008 | IOGear GBP301 Print Server
IOGear GPSU21 Print Server Logo
359 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
