Question about Frigidaire GLEQ2152ES Electric Dryer
Need to remove the front
Figidaire Gallery series GLE02152EE1 clothes dryer I have something stuck in the drum and need to take the front off with out breaking anything. Can you tell me how to remove the front?
  • 1,531 Answers
There are two screws on the back of the lid take those off then slide the lid off remove the screws that hold down the control the the screws on the inside of the cabinet that hold the front panel in place once removed the panl will pop off
Posted on Sep 17, 2009
Frigidaire gallery heavy duty dryer eating clothes
Hi leallen88
Your problem with the clothes being ruined is the seals on the front of the dryer are faulty and need to be replaced...but here are also a few more suggestions.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Mar 20, 2013 | Dryers
Frigidaire Gallery Series GLEH1642FS loud noise on final spin
It sounds like something has come loose or some item was placed in the unit accidentally and it got lodged in the drum. You will need to start by taking the front cover off and looking around the drum.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
The drum on my frigidaire Gallery dryer is tipped down , so there is a gap at the bottom and clothes get stuck in it. Can this be adjusted?
Suspect one or more failures of the drum front support bearings. Remove the cabinet top by removing several screws at the rear of the top, then pushing it to the rear somewhat which should allow the top front to lift up to allow removal of the front cabinet panel by taking out several screws on each side, then lifting the panel up to release it from the bottom. Once the panel is off, the support bearings should be mounted around the drum opening in the panel. Hope this helps!
Nov 20, 2010 | Frigidaire GLER341A Electric Dryer
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Clothes catching inside at top of drum
IT sounds like you have a roller that is broken or the drum is off track...when a roller breaks or the support bracket that the roller is attached to has a screw loose and has shifted position and I surmise based on your description that the front left roller is affected or the drum is off track up toward the front of the dryer...that would make the front of the drum drop creating the situation you described. The only way to get to this problem depending on the brand...is to remove the top of the dryer...or the back of the dryer...and remove the drum...to access the rollers.....be careful to observe closely how the belt is attached to the spring loaded arm (tensioner) that keeps the belt tight...and replace it the way it came out. Any problems get back to me and I can walk anyone with good mechanical skills through exactly what to do.
Hope this helps....please rate me...the Fang
Mar 25, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
275 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
