Question about TechnoMarine Raft Watch
How to adjust the crown of technomarine to adjust time
Just bought the watch, I set the time but the clock is not running. does it come with a battery? should I return it?
kindly check the lower sub dial if it is working. if yes, you don't have to worry because it is a chronograph. if not, check the crown if it is pushed down, if not, you got to push it, and if nothing happens you have to bring it back from the seller probably the problem is the battery. I hope i had been helped you.
Jul 27, 2011 | TechnoMarine NEO CLASSIC LADIES WATCH...
I was just given a black RSX 05 TechnoMarine chronograph watch, but the date is wrong. I can't seem to figure out how to fix it and I wasn't given an instruction book. How can I change the date?
your watch crown has 3 position. the normal position, the second position and the third position. pull it to the second position then turn it counter clockwise or vice versa. then push it to normal position if your done. i hope i had helped you..
Jul 10, 2011 | TechnoMarine Raft RSX05 Unisex Watch
Does the crown on the 609001 Technomarine have to be screwed in after the watch or date is set?
Yes, you must always screw down the crown. If not, you will get dirt, sweat, water inside and it will cost alot of money to repair
Jun 15, 2011 | TechnoMarine UF6 Lady Silicone Strap...
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Just bought a technomarine watch and can't pull out stem to set time and date
Sometimes the crown is screwed in to help keep it water tight. Turn the stem anti-clockwise to see if it will release "give several turns" if that fails return it for exchange.
Dec 31, 2010 | TechnoMarine CSX01 Wrist Watch
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
Hello, are there screw down crowns replacements for technomarine? mine fell off. Where can I find a replacement?
i too am looking for replacement screw down crowns...were you able to find them?
Apr 08, 2010 | TechnoMarine Watches
I have a Woman's Techno Marine CSX05-1036 watch and cannot figure out how to change the time
unscrew the crown a little so you can pull it out. this will allow you to change the date and the time. the first position is for the date and the second position is for the time.
Dec 03, 2009 | TechnoMarine Dial Chronograph Watch
Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Mar 22, 2009 | TechnoMarine Ceramique Watch TCB02C
Stress fracture in case
Contact Technomarine http://www.technomarine.com/
Jun 03, 2007 | TechnoMarine Ceramique Watch TCB02C
TechnoMarine Raft Watch Logo
99 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
