Question about Canon EOS Rebel XS 35mm SLR Camera
Cannon 35mm EOS Rebel X S Shutter Problem
I own a 35mm EOS Rebel X S, and whenever I do not use it in a while, the shutter does not open and close in the proper time, even in the automatic setting. There is some for of liquid on the shutter, but I have been told that it is just lubrecant...pls help
  • 149 Answers
Problem in shutter clean the shutter with white petrol dry it no need of lubrecant
Posted on Sep 11, 2009
Canon EOS Rebel GII With 35-80 Lens 35mm Film Camera shutter
In manual mode you should be able to change the shutter speed simply by turning the main dial (the thumbwheel located near the shutter release button).
Jun 28, 2012 | Canon EOS Rebel G-II 35mm SLR Camera
I'm using a Canon EOS Rebel X S 35mm SLR What setting should i set my camera for a manual shutter speed?
If your camera is a Rebel XS you should have a dial on the top right with a series of letters and icons. To set your camera so you manually control the shutter speed turn this dial too "TV" (Time Value). This setting will allow you to select the shutter speed and the aperture will open or close to achieve the correct exposure. The "M" is (Manual) where you would select both the shutter speed and aperture "AV" is (Aperture Value) where the user selects the aperture they want and the shutter speed increases or decreases to obtain a proper exposure. The "P" (Program) mode allows the camera to automatically select the shutter speed and aperture
Dec 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
My new cannon rebel isnt working, the lens will focus but the screen is black. cannot get the shutter to activate
Mirror mechanism is locked up and probably out o synch with the rest of the shutter cocking mechanism. sometimes there is enough power in battery to focus lens, but not enough to power the winder/shutter/miror mecansim- check the battery
Aug 24, 2009 | Canon EOS Rebel G 35mm SLR Camera
On/off switch
The Dial on the top, there is a red icon, it is the OFF button, any other button is swithched ON. Altough it doesn't matter at all because the only way the camera is ON is whenever you are flashing or shooting, or presing the shutter button halfway.
Jun 24, 2009 | Canon EOS Rebel X 35mm SLR Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Shutter stuck
not sure about the 'BC', but the shutter problem is most likely due to shutter oil leakage. do you see some shiny black oil on the edges of the shutter blinds? i've had this happen to me once and the repair shop managed to clean it. seems like a problem that bugs Canon EOS cams. Replacing the shutter would most definitely cost more than the value of the camera, so you might want to try this
http://photonotes.org/articles/oily-shutter/
Apr 28, 2008 | Canon EOS Rebel X 35mm SLR Camera
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Feb 14, 2008 | Canon EOS Rebel XS 35mm SLR Camera
Canon EOS Rebel XS 35mm SLR Camera Logo
455 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
