Question about RCA Lyra RD1072 MP3 Player
Won't stay on
I push the on/play button and it turns on for about 5 seconds and turns off. While it is on the LOCK icon is flashing.
What do I need to do?
  • Anonymous Feb 08, 2008
    i turn it on, it says please wait, the lock icon flashes then it turns off
    Sergeant:
  • 319 Answers
Make sure it's unlocked on the back.
Posted on Dec 31, 2007
  • ROOFERGIRL20 Oct 13, 2011
    This helped I thought something was wrong and I read this and realized its very easy to lock it when u turn it on...THANKS!
We should see if a new batery will help.
Posted on Dec 29, 2007
My whirlpool super capacity 465 oven won't turn on.
one of the buttons should have a small icon of a pad lock. press and hold it for 5 seconds. if not turn the breaker off for 5 min then turn back on.
Nov 24, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
Lost my FOB I have a new one but I cant turn the alarm off, I called harley and they said to turn on the bike and immediatly push both left and right blinker buttons, Ive done this probably 30 times and it...
OK so here is your solution. from your dealer when you purchased your bike with the alarm system you were given a 5 digit pin number. in order to turn it off manually you need to unlock (if locked) the switch, turn it to accessory.
push both left and right blinker buttons in
with the left blinker button is you "digits" so if (ex 56726) push the left button five times
to go to the next button push the right blinker one time then left six times
the right blinker one time and left blinker seven times
then right two times right once
left six times and right once. this will turn off the alarm
to program the fob you need to turn the ignition switch in a sequence of
on off on off on
with the blinker buttons you push
left left right left and your signals will flash the hazards twice
push and hold the fob button till the hazards blink three times and you have just programed your fob
push and hold your fob to set alarm and double click to disarm your alarm
Dec 12, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
Hi I want to program a new keyless fob. I have the original fob that works great.Do I need to do anything to the original key when I program the new fob? 2006 nissan altima
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Nov 16, 2009 | 2006 Nissan Altima
Battery icon flashing
Your Stator shorted out and is charging to hi, 17-18 volts. Turn your key off, put your brake on (on the left handle bar) lock in place. Push your override (yellow button on left handle bar) wait about 5-10 seconds, now turn on your key and start the bike. Keep pushing the overide button once v2.1 goes away and you'll get into the voltage of the bike. rev it up to 4 or 5000 rpm, what is the charge, my guess it is around 17 or 18 volts. rebuild your stator
Sep 05, 2009 | Polaris ATV
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
My Creative Zen has a white screen but syill plays music
http://www.youtube.com/watch?v=a8g0sh7pc54
1. Fully charge the unit
2. Get a song to play
3. Lock the device
4. Wait for black screen and leave it like that for 20 seconds
5. Hold the play/pause button down and move the side switch out of lock mode, then push all the way down (like you're turning it off) and release (back to middle position)
6. Release the play/pause button
Sep 19, 2008 | Creative Labs Zen Digital Media Player
Control lock light stays on.
Carefully and slowly look for a button, I dont remember which, but there is a button that duels as a child lock if held for three seconds, find this and hold for three seconds to fix:)
Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
RCA Lyra RD1072 MP3 Player Logo
141 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
