Question about Refrigerators
I NEED TO REPLACE THE CRADEL ON THE ICE DESPENCER
  • 1 more comment
  • kmoore160 Sep 09, 2009
    hi i need to take the front panel off to get to the despenser cradel the model # is ED25CWXTW00 DOSE THIS HELP KIM
    I NEED TO TAKE THE PANEL OFF TO GET TO THE ICE DESPENSER CRADEL THIS IS A WHIRLPOOL ed25dwxtw00 model# ty kim
    whirlpool mod # ED25DWXTW00
    President:
  • 2,976 Answers
What is the make and model number?
Posted on Sep 09, 2009
  • David Shaub Sep 09, 2009
    I'm not sure what you mean by cradel. If you're talking about the parts in the door, there is a trim cover that needs to be carefully popped off. There are 8 screws under it that hold things in the door.
    If you are talking about internal icemaker parts, rather than the dispensor, please try to describe what it looks like or does.
    Here is a link to all the diagrams for your model.
    http://www.pcappliancerepair.com/model-d...
  • 10,515 Answers
The best i can do, i can offer you a Service Manual :-
http://www.cagrimmett.com/justanswer/gegssprofile.pdf
It might not be of Your Make and Model, still it would help you as the basics remain the same .
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 09, 2009
    Thanks for your response!!
    It has all the information. Check the same.
    Thanks.
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
Ice Storage box
I have a Whirlpool Gold fridge model # GS5SHAXN LOO. The problem is this...often I'll hear a noise from fridge and when I investigate, it is always that a piece of ice has gotten stuck in the tray part of freezer and not falling into dispenser. Also, because of this it seems (not positive) that it won't begin the process of making any more ice. Annoying that we can't always have ice when we need it. Any solution to this would be great.
Thanks in advance!
Apr 17, 2010 | Whirlpool GS5SHAXN Side by Side...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WHIRLPOOL ICEMAKER DESPENCER STOPPED WORKING.
It is either the motor going bad or the switch at the ice lever. The little micro switch that is activated by the ice lever is likely held in place by two little, week, plastic pins. They break easily. After one pin breaks, the switch can still be close by the lever, but it is hit and miss. It is a ****** to replace the bracket unless you have some experiance. One other long shot would be the freezer door light switch that shuts power off to the dispenser when the door is open.
Apr 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fredge
is the ice maker set to make ice?..is it in the "on " position?
Feb 12, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
