Question about HP DeskJet D2560 InkJet Printer
Is there a way to reset the HP D2560 printer? cause i have refil the ink, but there is nothing being printed out.
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
SOURCE: can't print with my hp deskjet d2560
unplug both your data cable and power cable from printer. log off and log on the system. first try with test page printing.
Posted on May 09, 2009
  • 123 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
  • 4 Answers
SOURCE: How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: http://www.pokluda.cz/. You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Posted on Jun 06, 2010
Reset a hp 74xl printe cartridge
If this is OEM ink and not Genuine INK then you got to play it by ear. WARNING refilled ink does damage the print head in this unit and can cause undisired effects. If you have been using refilled ink for a while then your damage is already in its begining stages. But the indicator on these cannot be reset to estimate the ink because it does nto have a chip resetter in it. Thanks
Aug 03, 2010 | Canon MX310 Office All-In-One Printer
How can I make your 8500 pro accept a refilled HP cartrige.
The HP 940 cartridge is the new version of the HP 88 cartridge. Both have a chip that estimates ink levels. Once the chip says the cartridge is empty it will refuse to print, no matter how much ink is really left in the cartridge. This is a safety measure so you don't get air in your ink lines. If you get air in an ink line, that color will no longer print. We can refill the HP 88 because there are replacement chips available for these cartridges. I own a Cartridge World ink refilling store and I don't refill the HP 940s yet because I don't have access to a replacement chip. If you purchased a refilled HP 940 and it's not working, I would say the chip has not been replaced. I would wait until a reputable refiller (i.e.-Cartridge World, Office Depot, etc..) offers refills for this cartridge before you try anything off the internet.
Feb 16, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp deskjet D2560 new color cartridge fitted. No blue printing
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 16, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp d2560 tri-color cartridge not compatible
The print cartridge itself is faulty, you will need to replace it with a new one.
Aug 05, 2009 | HP DeskJet D2560 InkJet Printer
. HP 6210 all in one Kept printing till unplug
HP will tell you to never refill cartridges because they will not guarantee your printer will print properly with those refilled cartridges. If those refilled cartridges leak and cause damage to your printer HP will also not cover any repairs to the printer regardless of what sort of warranty coverage you have with them. Warranties only cover HP failures, not ones caused by using third-party or refilled ink cartridges. So, no it is not worth having the cartridges refilled - buy new HP-branded ones only.
Jul 25, 2009 | HP Office Equipment & Supplies
Can't print with my hp deskjet d2560
May 09, 2009 | HP DeskJet D2560 InkJet Printer
Refilling HP 56 Cartridge
USING THIS TYPE OF REFILLS JUST ISN'T A GOOD IDEA. THE INK IS NOT THE SAME AS HP CARTRIDGE INK AND YOUR PRINTER WAS MADE FOR HP INK, NOT SOME GENERIC BRAND. THE FACT THAT IT DOESN'T WORK UNLESS YOU STICK IT IN WATER, ETC. SHOULD TELL YOU SOMETHING IS WRONG HERE. REFILLING IS MESSY, AND CAN CAUSE LEAKS IN YOUR PRINTER AND REALLY MESS THINGS UP. THE BEST BET IS TO USE THE PROPER INK CARTRIDGE WITH YOUR PRINTER. THATS THE TYPE OF INK IT WAS DESIGNED FOR.
ARCLIGHT1217
Jun 05, 2008 | HP PSC 1110 All-In-One Thermal Printer
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP DeskJet D2560 InkJet Printer Logo
1,400 people viewed this question
Seeker5211
Seeker5211
