Question about Nokia 7373 Cellular Phone
Locked phone hi i have nokia 7373 it is asking me for pass code and i never locked it how can i get the code
bigjohn007
  • 425 Answers
SOURCE: Nokia 7373
if you can open your phone, try checking its flex connector maybe it got loose... thats the common prob...
 if you cant open it, find a service center near you...
Posted on Oct 21, 2007
270rexton
  • 762 Answers
SOURCE: My nokia e71 is asking for a lock code when i try to restore my factory settings
12345
Posted on May 30, 2009
  • 523 Answers
SOURCE: nokia 7373 security code forgotten ????
Hi Friend,
From the below link u can get the security code by providing your IMEI number,to get the IMEI number u must just*#06# or at back side of the mobile u will have serial number is as same as IMEI Number,
http://mastercode.nokiafree.org/
Regards,
Ayyasam
Posted on Jun 15, 2009
njvinod
  • 1462 Answers
SOURCE: Need Security code for Nokia RH 121
If you forget the security code, you get this error
DEfault code is 12345
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Please rate this solution
RNJ VINODKUMAR
Posted on Nov 11, 2009
Testimonial: "Thank you so much......worked on the first try!"
gal_kunchok
  • 229 Answers
SOURCE: NOKIA E63 ASKING FOR LOCK CODE
your imei
Posted on May 21, 2010
Hi is your phone asking for restriction code then it means your phone is locked to one network provider due to this it wont accept other network sim in it ....You can get restriction code from online sites like Onlinegsmunlock.com here they render unlock code for all mobile models ..You first check that whether they render code for your country and network provider ..If yes then pay for it and unlock your mobile ...
Jul 22, 2013 | Nokia (BL-4B) 1606/ 3606/ 2630/ 2760/...
After entering in the reset code the phone requests for the security code av tired 12345 , 00000 , all av failed . wat is the security code for nokia 7373
- To unlock you Nokia 7373 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Sep 14, 2011 | Nokia 7373 Cellular Phone
Does anyone know the unlocking code for a nokia 7373 thanks
Hi there, by logging on to the website http://www.mobileunlocksolutions.com/nokia-7373/rs1wp9/, you will be able to get unlock codes for your Nokia 7373 model mobile.
Jan 13, 2010 | Nokia 7373 Cellular Phone
Restriction code for nokia 7373 plz
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 07, 2009 | Nokia 7373 Cellular Phone
Want to unlock my phone online
hai,
This is a simple way to unlock your mobile.
This http://www.mobile-unlocker.com/nokia-7373/rs2wp9/ having the code and instructions for nokia 7373 mobile.
After open this page you have to select your country and network.It shows details.It is also an low cost.
Apr 27, 2009 | Nokia 7373 Cellular Phone
Nokia 7373 Frozen screen!
what is the imei number of the phone if you do not know you can take the battery out of the phone it is located to the back of the phone or you can press #06#
Jun 22, 2008 | Nokia 7373 Cellular Phone
u can try these two steps,i hope this would work out otherwise ull have to go to the nearest NOKIA CARE.
  1. first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
OR
2. type *#7370# & then your phone get restart type your
password like 12345 five digit numbers. your phone well
be working fine like as new phone
Nokia 7373 how to umlock my memory card
hey sally
have you tried using the default password or passcode? i think its 12345 for security code right?
anyway, you need a passcode in order for you to use the card and only the card.. if you still cant carack the code, you might as well reformat the card using a card reader/writer on a pc.
Apr 08, 2008 | Nokia 7373 Cellular Phone
My nokia 7373
Hi becky i can help you but the problem is if you have entered the wrong code more than 5 times then the only way too unlock it is by using flash lead and unlocking software and equipment witch would cost more than the phone new ok.
If you want your master code then i need your imei number its located on back if phone under the battery and looks like 1234/1234/`1234567 its 15 numbers long ok i need this as every phone has a different master code based on the imei number so if you want this code then let me know ok speak soon
Mar 28, 2008 | Nokia 7373 Cellular Phone
Nokia 727 PIN (lock out)
if it ever happens again and when the switch the phone on and it ask for the security code i can give you the overide code so if you get stuck post again ok hope this is some help to you
Nov 19, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
